Need a steel line reproduced
ILGLEANER View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ILGLEANER Quote  Post ReplyReply Direct Link To This Post Topic: Need a steel line reproduced
    Posted: 01 Feb 2012 at 10:00pm
Luke R was good enough to borrow a line off of his D21. It is the line from the Hyd. pump to the hyd block on the platform. Does anyone know where I could get a steel line made from a pattern?  It has multiple bends in it.
                                                     Thanks,
                                                        IG
ctbowles58 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ctbowles58 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2012 at 10:09pm
could you replace it with rubber? i did on my 190XT
Travis(NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Travis(NE) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2012 at 10:24pm
Wasn't JimWenigOH getting some made for a 190 back in November? Wonder how his turned out and if he would recommend whoevere made his?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2012 at 10:24pm
What size, how many bends, what type of connector? Tracy Martin
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2012 at 10:28pm
I got one of the lines that Jim Wenig had made, it seems to be a good job. So if Jim would see this post, or you could PM him, and he could put you through to the company he used. Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote ILGLEANER Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2012 at 10:31pm
Tracy if you think you could make it I will bring it with me this weekend. I am coming your way.
                                                        IG
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2012 at 10:40pm
John, without seeing it I don't know. I am not familar with that particular line. Sounds like Jim might have already done the hard part. Tracy Martin
Redwood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Redwood Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2012 at 7:09am
Woke up and reread the post...I retract that comment. but no delete button
Edited by Redwood - 02 Feb 2012 at 9:01am
StewartMD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote StewartMD Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2012 at 7:15am
There is a local ag parts store here that makes custom steel lines.  They will match what you bring in.  Sometimes when you put it back on you might have to tweek it a bit or they recommend putting a 1' piece of rubber line at the end to give you some flex to guarentee that it will fit.
8030, 8010, 220, 185, 160, D-17, WD, Unstyled WC, CA, G, 20-35, Gleaner E
Butch(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2012 at 7:23am
I dont know where Jim has them made but there is a place here in Columbus called Mid-state hose and fitting and they can replicate just about any steel line or fitting a person can come up with.
Mid-State  http://mshose.com/
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedBuiskerN.IL. Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2012 at 2:58pm
I had a return line from the transport valve back the hydralic sump for my D14 made at my local big truck repair facility.   Metal specialties.
JimWenigOH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimWenigOH Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2012 at 4:26pm
The company that made the tube for my 190 was Mid-State Sales in Columbus, OH. Ask for Nadine Lewis 800-421-7051, extension 21. This is an excellent company to do business with, and the tubes I had made fit perfectly. They had multiple tight bends, one being right at the end of the tube. Your best option in my opinion would be to have 5 made, and sell the rest here on the forum as I did with my extras. My local Agco dealer bought one of mine too. You will cut your cost per unit quite a bit going this route, and help others as well.
amac View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote amac Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2012 at 5:50pm
I don't know how far from Burlington Ia you are but there is a place called Brozene hydraulic. They can make about any steel line or hose up to 6000 psi. They made a steel line for my 220 from the valve to the lift arms.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ILGLEANER Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2012 at 4:54pm
amac ,
    I brought the line from near Burlington Ia , To try to find someone to make me one. Wish I would have know that. Thanks for all of the leads
                                                  IG
