Need a idea?
Dave in PA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in PA Quote  Post ReplyReply Direct Link To This Post Topic: Need a idea?
    Posted: 09 Nov 2013 at 3:10pm
Have a lawn and garden tractor, used, that I just bought for the snow plow purpose. Got the wheel weights on, and the tire chains. What is the best method for the chain tight-in things! LOL The rubber loop ones with the weights don't seem like they will work? any ideas??
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2013 at 4:52pm
We take iner tubes and cut them in small strips as rubber bands and use the hooks from the cross pieces off the tire chains.
acd17toy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acd17toy Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2013 at 8:21pm
               I   never use those rubber chain tighteners, just get the chains as tight as you can  when installed the first time and after you  run them for awhile retighten them again.
truckerfarmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote truckerfarmer Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2013 at 11:05pm
What I do is let a little air outta the tires, put the chains on, then air up the tires. Tires will be tight and not come loose.
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2013 at 8:05am
I do the same and I also got the 5 pointed spring tighteners from tirechains.com, or whatever that sites name is!  The only problem I have is the cross chains wearing out.  But that is only every 8 - 10 years, so I just live with it!
