Need 3 HD5/6 Track Links |
dyno
Joined: 03 Jan 2010 Location: Middleton, ID Points: 70 |
Topic: Need 3 HD5/6 Track LinksPosted: 01 Sep 2010 at 8:40am |
I found a good used track in the boneyard up at my ranch but is 3 links short. Anyone have 3 good links with P/N 078835, 078836?
Looks like the only difference between the different P/N's is that the 078835, 075836 has much stronger webbing between the rails less likely to break.
dadsdozerhd5b
Joined: 27 Sep 2009 Location: lansdale pa. Points: 537 |
Posted: 02 Sep 2010 at 4:18am |
i may have a few after thinking about it. i will be to my storage yard this weekend i will check. do you need the pin and bushing? the part number was just for the links.
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42270 |
Posted: 02 Sep 2010 at 5:47am |
Sounds like he is making 5B track into 5G length or? believe he needs it all
dyno
Posted: 02 Sep 2010 at 8:17am |
I need 3 complete links with pins and bushings. The track I found only had 30 links, I need 33 on my dozer.
Coke-in-MN
Posted: 02 Sep 2010 at 12:25pm |
http://www.northernengine.com/
They have a place in Gelette WY
May try Thill Track and Tractor in Eau Claire WI also .
You could add in those three links using 2 master pins and bushings in track
dyno
Posted: 02 Sep 2010 at 9:49pm |
Thanks Coke...yeah, I plan to add the missing three links just like you said.
Will check out the sources you ref'd.
Thanks,
dyno
