Narrow Front vs Wide Front?
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Topic: Narrow Front vs Wide Front?
    Posted: 16 Jan 2011 at 9:17am
I like wide fronts for makeing hay so you dont crush as mouch crop, but other that safty, stubitially. But for small tractors i would perfere Narrow fronts you can put a tractor anywhere , you can turn sharp, and i always thought they made the tractor like a tank because they were one piece and not a clumsy wide front in front. So what do you perfer on small tractores wide or narrow?
Edited by R.W - 16 Jan 2011 at 11:06am
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2011 at 10:12am
Definitely wide front for safety reasons.  Much more stability, especially when crossing the side of a hill.
Burgie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Burgie Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2011 at 10:32am
Just depends on what the job is.
"Burgie"
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2011 at 11:19am
On a side hill the small tractors are not really more safe from tipping.
Denis in MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Denis in MI Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2011 at 11:28am
you are right Dick L, a wide front just makes you feel safer on a side hill, but any tractor will turn over don't anybody fool yourself on that.
1938 B, 1945 B, 1941 IB, 1949 C, 2 1938 WCs, 3 1950 WDs, 1951 WD, 2 1955 WD45, 1957 D-14
omahagreg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote omahagreg Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2011 at 11:46am
Dad and Grandpa farmed in gumbo.  Could not use a narrow front, as it would get packed in there and then you were plowing, not driving anymore.
Greg Kroeker
LionelinKY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LionelinKY Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2011 at 11:48am
I consider myself old school so I believe that you can't beat an old NF as a cultivator tractor though you'd never get done with today's acreages. They also work the best come fall for getting all the equipment squared away backed into the old machinery shed. Other than those 2 tasks, I'll go with the WF for increased stability. Notice I didn't say guaranteed stability.
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2011 at 12:18pm
OK, I'll dissagree with Dick.
If you are crossing a sidehill and your narrow front drops in a badger hole, the front end drops 10" then pops out of the hole and throws the whole balance of the tractor to the downhill side.  It probably jerks the steering wheel right out of your hand in the process, adding to the unsafe condition.
When a wide front encounters the same hole, the front end only drops 1/2 the distance  or 5" and you barely feel the effect...steering is minimally effected. Also most tractors with wide fronts have stops built in so they only pivot so far....unfortunately the little B isn't one of them.  Check out the Wd, WD45 and on up, they can all only pivot a small amount. I've had a lot of them hanging on one front wheel when going thru a ditch.
Probably the biggest advantage to the wide front in this situation is the front wheel acts as a scout to check out the terrain before the rear wheel finds it.  I have found this out countless times when I am out brushhogging in tall grass...if that downhill front tire drops, I stop and check out the situation before proceeding! In many cases if I was running a narrow front tractor, I would have rolled it because I would not have had a warning of how far the rear wheel was going to drop.
ALLIS EXPRESS!
This year:
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2011 at 12:41pm
I'll have to agree with Eldon. A narrow front end is great for many reasons...fitting more tractors in a shed/barn easier,for use as a plowing,discing,brush hogging,etc. tractor on flat to gently rolling ground. However,if I'm logging or dragging firewood tops through the hills and hollows like I do,then you'll only see me doing so with a wide front tractor for safety reasons. Don't get me wrong,you can overturn a wide front end tractor just the same,but I think that's because some people get a little brave knowing this. That's why I always have and always will have respect for machinery. It has no feelings!  Rick
Lester View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lester Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2011 at 12:42pm
Wide front are a lot safer, ride smoother, steer easier, go much farther in mud and snow.Narrow front are okay for parking on a lawn or shed ,not  as good for real work in field.
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2011 at 1:03pm
I'll take a wide front over a narrow front, I think they have a safety advantage, and in my own opinion, I just like the looks of em better, Darrel
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2011 at 1:06pm
Narrow front tractors have historically been referred to as 'row-crop' tractors for that reason.  With the narrowing of rows and virtual elimination of mid-season cultivation for large field crops, the need for NF as field tractors has all but gone... some truck-farming operations still benefit from row-crop clearance.
Geometrically, 3 points defines a plane... so in ideal circumstances, with proper weight on the wheels, a NF tractor SHOULDN'T be any less-safe than a WF...
(notice I didn't say 'safer'... I said 'less safe').
Tractors drive in places where the world ain't always flat, and they don't have a center of gravity that is particularly low, therefore, they roll over.  The tractor I prefer, is the one that I'm not on when it rolls.  The WORST tractor to be in, is one with a full, protective cab, upside down, in a full creek... with all doors and windows blocked.
The tractor to collect, if you have limited space and budget, is the NF, because they 1) Park very close and 2) due to demand, are frequently less expensive than a WF.  Finally, 3) you can walk around or stand next to the engine, without tripping over the front axle... so nicer to work on in the shop.
They're like women-  come in all styles and colors, and sooner or later, every one of 'em will somehow drive you crazy... but I'll take 'em ALL.  Even GREEN tractors are fun to ride, just don't let your friends catch 'ya doin it!
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2011 at 1:28pm
I'm not saying which is better WF or NF. I was working at a dealership years ago and saw a 460 Farmall go over sitting on flat ground, the setup guy was unloading a disc that was hooked to one side of the loader  (tractor had a WF) and he lifted the disc up and backed away from the trailer and the tractor when over on it side. The guy jumped off just in time. They will all go over. Don
DonBC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonBC Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2011 at 1:58pm
The stability issue is largely related to the centre of gravity(COG) and the point of rotation. At the rear of the tractor the point of rotation is one of the rear tires so a wider stance is more stable and more weight at the rear is also more stable. At the front end the point of rotation is the bottom of the front tires of a NF and the centre of the pivot pin on a WF. On flat ground the COG is directly above the pivot point of both types and the pivot point of a WF might be as little as 1/3 the distance to the COG than the pivot point of the NF. If the tractor is on a side slope the COG shifts to the low side of the pivot points. If you draw a straight line vertically down from the COG the COG is a lot further to the side of the pivot point of a NF than it is from the pivot point of a WF. If the length of this horizontal line is considered as a representation of the difference in overturning force it is easy to see graphically why the NF is not as stable as a WF. This becomes even more pronounced if you add a FEL and raise a loaded bucket above the normal COG of the tractor because it moves the combined COG even higher and makes the NF even more unstable. Sorry for the long post but it didn't seem as if some of the respondents understood how the location of the pivot with respect to the COG affects stability.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lester Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2011 at 3:05pm
It is common knowledge to older farmers who were around a lot of rollovers in the 50s and early 60s before wide front ends were popular that the nfes rolled quicker, were harder to steer ''no powersteering'' and ruffer to ride on. Some only kept  nfe on farm for a cornpicker.. Why dont the still make them if they were so great?
Lars(wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2011 at 3:59pm
I planted corn and cultivated with a narrow front Case 830 Comfort King diesel, worked great for me. also baled with same tractor untill the pto got weak.
BStone View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BStone Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2011 at 4:13pm
I think the NF are just as safe as the WF....if your on a very hard flat level surface and driving Real slow.Maybe they are good for steering in tight places in a building, but I don't buy are use a tractor just for that purpose.Other than a corn picker tractor I have no use foe them.I know some people like them so it's a buyers market where I live because you can't hardly give one away.BStone
Matt (NEIA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt (NEIA) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2011 at 9:55pm
the narrow fronts witout power steering steer easier than a widefront also without power steering in my opinion, atleast they do with the ones i've operated
1955 WD-45 with factory PS
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2011 at 10:15pm
DonBC,
I'm not an engineer but I have a sense about things mechanical.
You explained why, as I've always said, the WFE has an advantage
on side hills.
Thank you.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2011 at 10:26pm
I like them both. Nothing prettier than a B on full steel, or a NF 170, wish I had both of them. Tracy Martin
Edited by Tracy Martin TN - 16 Jan 2011 at 10:27pm
Chris (swIA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris (swIA) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2011 at 10:34pm
Your stability triangle includes the 2 rear tires and the pivot of a wide front or the narrow front. DonBC is right that the center of gravity shifts a little with the wide front versus the narrow but it is a matter of an inch or 2 difference in tipping. most of the older wide fronts weren't built heavy enough to prevent a roll over once it starts, they would break off. I still think that it is a false sence of security and if your are running that close you are just asking for trouble down the road. Personally, I get nervous way before the tractor would come close to a roll over. I have never had to send $500 to rebuild a narrow front.
Steve M C/IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve M C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2011 at 12:04am
The biggest "saftey factor" for wide front is as previously stated.It finds the hole/wash first...while there is still time to avoid trouble.
Reeseholler View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Reeseholler Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2011 at 12:05am
For me it depends on use. My Farmall MD I just got, I bought it partially because of the WF. We do a little baling hay so not only does it not run over the hay, I can take turns a little bit shorter and quicker with the rake on a little slant. I shouldn't say I'm never careful enough, but I don't get in a hurry. If I hurry I forget something and it seems like safety is the first to go.
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2011 at 12:13am
I can't disagree with the safety factor but a NF is sure handy for pulling a grain drill, can turn shorter also for cultivating dry beans and corn for us who don't like to support big M.
Allis Express participant
Andrew(southernIL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Andrew(southernIL) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2011 at 11:07am
I would say the best job for a narrow front is a post hole digger. At least for the people who like their post to be exact. I know some guys that had a NF 3020 and it was probably their most solid tractor but it just sit in the shed with the post hole digger for fence building unless too many of their other deeres were broke and had to use it.
If fishing is a sport your looking at an athlete
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonBC Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2011 at 12:51pm
I feel that I need to add more clarity to my previous comments. When a tractor starts to turn over on a side hill the rear wheel on the high side will start to lift and the tractor will rotate about the lower rear wheel and the front pivot point. On a NF tractor both of these pivot points are at ground level and with a higher clearance tractor as NF tractors typically are the COG can be 3' or more above ground level. On a side slope the COG shifts to the low side and with enough side slope the tractor will turn over particularly if a rear wheel hits a hole or a bump. With a WF the front pivot point is higher and closer in height to the height of the COG. It takes a steeper side slope to shift the COG enough to the low side on a WF to make it unstable. The stance on the WF and the axle stops really don't come into play until the high side rear wheel has already left the ground and by then it it is too late for the front axle to stop a rollover.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2011 at 3:48pm
Yeah, Don- I suspect that some of the guys didn't follow the 'pivot point' reference.
What he's referring to, is that when the tractor rolls from side-to-side, the 'pivot point' of the front of the NF tractor, is where the tires touch the ground.  On a WF, the 'pivot point' is where the axle contacts the tractor frame... the axle pivot.
Let's say (just for the sake of reference) that the tractor's center-of-gravity is right down the middle of the crankshaft.
Measure the distance from center of crankshaft, to the axle pivot of a WF.  Let's say that's 10".
Now measure the distance from center of crankshaft, to the 'pivot point' of an NF... that is... where the NF's tires touch the ground.   That's gonna be more like 40" or so.
Difference:  10" vs. 40 inches.
Now, take a bob-weight on a string, and tie it to the center of the crankshaft.
Put both tractors on the same hill... sideways.  Measure the distance between the pivot point... and where the bobweight's string is.
Bobweight is telling you where the tractor's weight WANTS TO GO.  Notice the distance between where the bobweight is, and where the tires contact?  With the WF, the tractor's weight wants to go somewhere that's still INSIDE the envelope of rolling wheels.
Now, if you do a 'true' center-of-gravity, you have to do it on all three planes.  With the weight of the wheels, ballast, transaxle, etc., that means the actual center-of-gravity of the machine is somewhere more towards the CENTER of the tractor... say... somewhere in the middle of the transmission.  IF you have an NF tractor, where the wheels are spread really wide, and ballasted low, not only will the center-of-gravity will be low, the WHEEL PATH will be so wide, that the tractor's total center-of-gravity will  always pass WITHIN the path, rather than outside the path.
Regardless, my preference, is still to be nowhere near the machine when the tipover point is found.
RSponenberg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RSponenberg Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2011 at 4:09pm
I have one of each in WD45s !!! The narrow front is used for plowing with 3 bottom 16" plows keeps the steering tires out of the furrow,also used for backing wagons into the barn,much easier with a narrow.The wide front is used mowing and crimping and runnning the baler,but also have a wide front CA to help out there!!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2011 at 4:21pm
I like the wide front for mowing the ditch. With the wheels on one side on the road and a front wheel running along the edge where you can't see if there is a hole or washout, you don't find that hole or washout with the back wheel which almost guarantees an upset. Otherwise, NF tractors can take up less space on a trailer or shed. I can mow parts of the ditch with my wide front CA that I wouldn't dare try with the D17 with it's NF.
Edited by Brian Jasper co. Ia - 17 Jan 2011 at 4:23pm
This page was generated in 0.081 seconds.
