Narrow front on 720 garden tractor
den/southern illinoi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote den/southern illinoi Quote  Post ReplyReply Direct Link To This Post Topic: Narrow front on 720 garden tractor
    Posted: 29 Jan 2011 at 8:38pm
A year or so ago I dreamed of putting a snap coupler system on one of my 720 lawn tractors.  That's still on the list of things I want to do when I get around to it.  In the mean time, another nightmare (as my mechanic friend calls them) has come to mind...putting a narrow front end on a 720.  Don't think I've see it done on this large of a garden tractor.  I'd like to keep it a working model...not just a show piece.   Just one of my dreams???
Den
Own 4 wheel 20, 5020 and associated equipment and 1 electric forklift. Also a 720 garden tractor, 720 Diesel. 620 and soon a 616 garden tractor.
Jacob (WI,ND) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jacob (WI,ND) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2011 at 8:43pm
Are you thinking of putting larger rear tires on so you could keep the original size fronts and still have the tractor sit level?  Or?
I like it.  Not sure what purpose it would serve being a narrow front, but when has that ever stopped us from doing something, LOL!
I know I have some "nightmares" in my mind too....
Jacob Swanson
1920 6-12; 1925,1926 20-35 longfenders; 1925,1926 15-25's; 1927,1929 20-35 shortfenders; C; B's; IB; WC's; WD; WD45
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2011 at 8:53pm
Den, I have had dreams of owning a 720. Maybe some day if I get rid of some of the big stuff, I can go to smaller stuff.
Post Options Post Options   Thanks (0) Thanks(0)   Quote den/southern illinoi Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2011 at 9:08pm
Jacob,
I was thinking that I would keep the same size rear tires but try to put some tires under the front that would be to scale.  It would look like a narrow front 190.  Den
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jacob (WI,ND) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2011 at 9:14pm
Originally posted by den/southern illinoi den/southern illinoi wrote:
Jacob,
Ya, I'm with you on the 190 thing, but, just thinking out loud here, wouldn't larger rear tires/rims actually be closer to making a scale tractor than making the small front tires/rims even smaller?  I guess that's how I see it in my mind, maybe I'm off.
We need one of our fellow forum artists to draw us up some sketches....
Any thoughts on how to get the steering to work?
Jacob Swanson
Walker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Walker Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2011 at 9:15pm
When you get the narrow front put on. Post pics please. I'm rootin for ya, I think it would look really good.
427435 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 427435 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2011 at 10:36pm
Remember that the tractor will be easier to tip on side hills with a narrow front end.
There was a neat looking scale model D21 built from a 720 rear end as well as a scale model 190 with a 720 rear end at the Western Minnesota Steam Thresher's Reunion this fall.
Edited by 427435 - 29 Jan 2011 at 10:38pm
Mark
B10 Allis, 917 Allis, 7116 Simplicity, 7790 Simplicity Diesel,
GTH-L Simplicity
Ignorance is curable-----stupidity is not.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2011 at 12:34am
Anything is possible with enough $$ and some determination. I've seen Cub Cadets and JD 140's customized like that. In both cases they had to give up using mid mounted mower decks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote den/southern illinoi Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2011 at 4:31pm
427435,
Thanks for the warning but I was driving narrow front WD when I was 3 years old thru the hay fields while the adults were loading the wagons.  Brought up on narrow front end tractors and always seek them out.  I have a narrow front end D 17 and made the mistake of letting a NF D 19 get away from me.  I do believe that when it gets too steep, I let my brother Ron get it with his WF D 19,  Den
