Name this Allis and components ?
Macon Rounds View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Topic: Name this Allis and components ?
    Posted: 21 Mar 2012 at 3:26pm
Name the tractor,
Name the hoe?
Name the loader?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2012 at 3:29pm
BLee Mn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BLee Mn Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2012 at 3:35pm
i'd say it looks like a D-19D tractor, but after that no clue
Cowboy UP
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2012 at 3:46pm
D-17 Series III industrial diesel with a TS-1000 loader and a Mark IV hoe.
The loader and hoe are Henry products.
Edited by Calvin Schmidt - 21 Mar 2012 at 3:47pm
Dave (Mid-MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (Mid-MI) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2012 at 3:51pm
Tractor appears to be industrial D-17 with shuttle. Don't know about hoe or loader.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2012 at 4:18pm
Bill, Frank and Joe. Anything else you need named? ;')
Wink
I am a Russian Bot
Thad in AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2012 at 5:10pm
Lonn ya beat me to it.LOL
The tractor - Betsy
 The hoe - Doug
the loader - Hoss
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2012 at 2:03pm
Very Good Fellas !
Yes it is a industrial D17 series III diesel with shuttle shift.  1963 S/N 70546D
The hoe is a Henry Mark-IV s/n 3A1518AC
The Loader is a Henry TS1000 S/N 33I3AC
It's fun to see all the responces.
Anyone know of or have one set up like this?
Dave in il View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in il Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2012 at 9:21pm
I've never seen one other than pictures but I'd sure like to own one.
AGCO My Allis Gleaner Company
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2012 at 6:18am
Calvin has it all the way!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2012 at 6:47am
OK, I cheated a little. Had to check a brochure to see if it was a TS -1000 or L-200 loader. It is a very rare comb and I've never seen one for real. I've never understood why A-C built the I-60/600/615 on the D-15 tractor instead of the D-17.
cmsmoke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cmsmoke Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2012 at 7:16am
I don't see a "ho" on that tractor...OOPS!
Looks like a good start.
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2012 at 9:53am
The hoe is real similar to the AC 615 detachable hoe I have that came off a HD4 loader. Same type cesna swing rotary piston, but the legs are mounted a little higher on frame. This unit is 4 stick where my 615 is 2 stick for hoe controls.
TomMN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomMN Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2012 at 10:41am
My D17 Industrial is a gas but was probably set up just like that.  It still had the TS1000 loader but the hoe had been removed with a cutting torch.  Here is a link to some pictures of mine - It is now disassembled and only the loader is outside otherwise not much in the line of progress.
http://home.comcast.net/~old_allis/ac-D17.html
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2012 at 11:04am
Yea Calvin you hit it right on the nose.  Good Job.
Coke, I believe the reason Allis didn't make the D17 the power plant for their Back Hoe and loader combo was three fold. It is a powerful beast. Over 11,000 Lbs without loaded tires or ballist, The turning radius is not condusive for tight quaters.  And the power steering is slugish as it has the same power assist system like the farm tractors.
   The i600 and an i40 will both run circles around and inside this old D17 because of the shorter lenght between drive and streering axels and the true power steering they have.
   The good thing about this old D17 is it runs better than any of the other Budas i have and the hoe has litttle or no wear.  Yee Haw !
  Tom, i saw your D17 industrial when you first posted the photos, although it was in bad condition i was jelious. Now i found this beauty and my wife is calling it my Girlfriend. Ha ha!!!  SHe is a beauty.   How is you D17 industrial project comming along?
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomMN Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2012 at 1:39pm
I wish I had some progress going on mine but at least the major pieces are inside out of the elements.  The engine in mine looked good from the outside, but when I took it apart I found it split at the bottom of all the sleeve webbing.  The center web was split through to the main bearing, so the block in mine was scrap.   I have a replacement block that I think is OK but I haven't done much more than take it apart and verify that the bottom isn't split out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2012 at 6:35pm
How does the shuttle shift feel.  Does it lock up good in forward and reverse ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomMN Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2012 at 6:45pm
The shuttle seemed to be pretty good, I have that shimmed up and ready for whenever I get around to putting some time into the tractor.
