Nail in tire
ACinSC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Topic: Nail in tire
    Posted: 15 Aug 2024 at 3:18am
Saw a nail in a guys truck tire. He told me it wasn't leaking air so he leaves it alone. If I see a nail in my tire I fix/remove it. Any thoughts? Thanks
thendrix View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote thendrix Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2024 at 5:50am
He'll learn that soon. The nail went in and it's going to come out
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2024 at 5:56am
It may take MONTHS for it to come out depending on type of nail,size, head, temperature, air pressure,roads, etc.
He's 'driving om borrowed time' ?  Putting off the inevitable ??
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2024 at 6:21am
Inevitable
Reported a nail in tire in my city vehicle. Fleet assessed it and removed the nail as it was not leaking. 2 weeks later I had to report a flat tire.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2024 at 6:21am
Thanks guys. I agree.
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2024 at 8:25am
A nail in a tire is an obvious problem.
Many wheeled military tactical vehicles have a centrallized tire inflation system that will replenish losses if a tire is breached, which can be a very critical thing under combat conditions... like, when you're getting shot at and can't get out to pull out a nail...
And if I'm on the road and discover a nail through a tread, I'll drive to a repair shop... and if it's not gonna make it, I'll pull the nail and stuff in a slimey plug...
But dismissing a breached tire on a car is idiotic.  It's GONNA fail, and it's gonna kill a perfectly good tire doing it.
Dismissing it in a trailer or truck tire... anything over 40psi... is a very dangerous problem.
People think that a tire that has a nail puncture will leak down and fail slowly... this is not always true... and when one tire goes, it can often take the adjacent tire WITH it.
desertjoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2024 at 8:30am
 That nail "WILL" come loose and start leaking air when the dude is many miles from civilization and his spare is flat and his neighbor borrowed his jack and ,,,,and,,,Ain't brought it back yet,,,,,LOLLOL THEN,,,,his cell phone battery goes belly up soon after,,,,,WinkWink
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2024 at 8:37am
Yeah I keep an eye on my tires. If I see something suspicious I check it out. Thanks guys
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2024 at 11:41am
I usually remove nail and patch with plug . Then take off when I have time and have tire place patch from inside.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2024 at 2:55pm
If you have a problem,fix it. Otherwise you are just asking for more trouble.
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2024 at 3:45pm
I had a screw in a tire on my dump trailer for about 3 years. If the trailer set for a month, it would go flat. I would pump it up, use it and, of it sat, it would go soft or flat again.  I used it that way until I had a 180-mile (one way) trip to make with it. I had a heck of a time getting the screw out.
I finally got it out and plugged it. That was a couple years ago. No problems since.
cal222 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cal222 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2024 at 11:37pm
When I have such issues, I try to put it off as it is an inconvenience, but I never just live with it, he must be standing on thin ice, then when the inevitable happens he'll ask "what's the cause of this?"
