N7 Gleaner question
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Topic: N7 Gleaner question
    Posted: 05 Aug 2023 at 6:16am
curious... what's the big vertical disc do ???
https://www.kijiji.ca/v-farming-equipment/saskatoon/1983-n7-gleaner/1663542897?cid=f71ddf75-c892-4bb7-9057-ecf2c8d5c35a
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2023 at 6:20am
It swings or bolts down underneath the straw chute to spread straw farther than the original design. Looks homemade. I don't see any paddles on it. Maybe it was for making windrows ??
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2023 at 9:20am
Like Doc says, definitely someone's homemade contraption. Nothing that gleaner ever put on from the factory
Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2023 at 9:27am
thank you !
Had a Gleaner A, once, sigh,.... jes curious......
GM Guy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GM Guy Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2023 at 11:04am
Looks like its in the windrow position, like said, home made setup, looks to be based off the super spreader kit that Gleaner offered for the N series.
That bracket sure looks like a Vittetoe Chaff Spreader.
If that price is in Canadian dollars, definitely not a bad price if its a runner and you want one.
83 has quite a few improvements, and the big 516 engine in the N7 is way better than the wrung out 426 in the N6.
Edited by GM Guy - 05 Aug 2023 at 11:06am
If you need parts for your Gleaner, we are parting out A's through L2's, so we may be able to help.
