N5 unloading auger Drive Shaft |
orangereborn
Topic: N5 unloading auger Drive ShaftPosted: 24 Sep 2023 at 1:07am |
Looking for N5 unloading auger drive shaft. Need tube end that is on the bin auger. Or at least just the yoke... (7)10323722 I think...Thanks...Dale
Joined: 11 Sep 2009 Location: illinois Points: 90826 |
Posted: 24 Sep 2023 at 8:09am |
Dale... i have had real good luck with these guys on PTO parts not available at local Tractor Supply... The FIRST thing you need to know is the BEARING DIAMETER of the U JOINT... That tells you the SERIES of the parts... Could be 1-1/8 , 1-1/4 , 1-3/8.. etc..
Here is the common 1-1/4 bearing size parts ( SERIES 35)..... once you know the SERIES, you can scan down the list and find a YOKE that has splines, hole, keyway, square drive, etc. Edited by steve(ill) - 24 Sep 2023 at 8:10am |
steve fischer
Joined: 11 Jul 2011 Location: sleepy eye mn Points: 1019 |
Posted: 24 Sep 2023 at 10:15am |
have a n5 for salvage
orangereborn
Posted: 29 Sep 2023 at 1:14am |
orangereborn
Posted: 04 Oct 2023 at 11:12am |
I think I may have found the yoke...John Deere OEM??
