N5 separator clutch issue |
AC 426 power
Topic: N5 separator clutch issuePosted: 07 Jul 2025 at 5:57pm |
Double post
Edited by AC 426 power - 07 Jul 2025 at 5:58pm |
AC 426 power
Posted: 07 Jul 2025 at 5:13pm |
Thanks for all the replies, the next day I went and tried it again and it worked fine, only thing I did add a gallon of ATF and gave the clutch a good greasing again and it never did it again.
tbran
Joined: 14 Sep 2009 Location: Paris Tn Points: 3642 |
Posted: 02 Jul 2025 at 8:31am |
Ah the old split main clutch shaft issues. You have had excellent advice here - just an explanation. The reason to disconnect the supply hose is to eliminate the 2% possibility there is something wrong in the valve stack. IF no oil squirts out of the hose (thus meaning the clutch is doing what it is supposed to be doing) then you might as well get a book, follow step by step and repair the mechanical issues which could the aforementioned pilot bearing, the floater pins, warped clutch or separator plates. The company even provided a ledge to lay the LH assembly on while you are in there fixing everything. :-) Thank goodness for the evolution to the one piece main clutch shaft.
darrel in ND
Joined: 22 Nov 2009 Location: Hebron, ND Points: 8776 |
Posted: 01 Jul 2025 at 8:30am |
Clutch pins also could be so badly worn that they are causing a bind that won't let the clutch fully separate when disengaged
Darrel |
darrel in ND
Posted: 01 Jul 2025 at 8:28am |
Try unhooking the hydraulic hose running to the rotary coupler on the separator clutch shaft. Start it up. Do not engage the separator clutch, see if separator turns then, or if oil spurts out of the hose
Darrel |
AC 426 power
Posted: 30 Jun 2025 at 9:11pm |
Gotcha, yeah have to tare in to it I guess, hopefully it can be fixed without spending what the whole machine is worth! |
Posted: 30 Jun 2025 at 8:55pm |
Gotta ask !!! Many second and third owners have not a clue about that bearing. If the separator is creeping on its own, the only way is something wrong in that clutch area.
AC 426 power
Posted: 30 Jun 2025 at 8:45pm |
Yes I certainly do know where it’s at, weekly? No I don’t run that many acres and don’t put that many hours on it. But it does indeed get greased, hell it only takes me a day to run the wheat I have. That’s why I run a junky old N5 to start with. So you thinking the bearing is failing? |
Posted: 30 Jun 2025 at 8:21pm |
Sooooo, you've been faithfully greasing the separator clutch bearing once a week right ??? Or do you even know what I'm talking about ??
AC 426 power
Posted: 30 Jun 2025 at 6:36pm |
Getting ready to run some wheat with my N5 and I noticed while hooking up the header that the straw spreader and the sieve was rotating very slowly without the separator engaged, then I heard kind of a bang noise, separator will turn on with the switch fine, but did the same thing when I turned it on and off. Any ideas? Thanks!
