mystery tube |
lost in h3
Topic: mystery tubePosted: 06 May 2024 at 9:41pm |
On my H3 which is just about complete there is a tube at the back left side of engine. This tube does not have a cap (lost). To be clear, when sitting in seat it is in front of gas tank on left and behind engine. i do not know what this is for. Does a dip stick go in it or a breather cap. I can't even figure out where it goes. I'm close to changing all fluid's and need to figure this out.
im4racin
Joined: 12 Jun 2017 Location: Garrison ND Points: 1124 |
Posted: 06 May 2024 at 10:04pm |
This tube about an inch or so tall at a bit of an angle outward with miniature radiator neck on it?
lost in h3
Posted: 06 May 2024 at 10:40pm |
Exactly
im4racin
Posted: 07 May 2024 at 6:38am |
It should be a dip stick and breather cap. Same as on a d14 or 15
lost in h3
Posted: 07 May 2024 at 12:54pm |
thank you
what is the dip/breather for and do you add fluid there. how long is the dip stick?
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 55247 |
Posted: 07 May 2024 at 3:24pm |
If its on the torque tube, about 4-5" long, and its for hyd pump reservoir, if so equipped...at least on a d-14-15, nit its on the other side...
im4racin
Posted: 07 May 2024 at 6:49pm |
Depends on how the crawler was set up. It is the circulation pump for shuttle and in some cases it’s the hyd pump too.
