My Uncle's One-Sixty Restoration (Update 04-23-18) |
Page <12 |
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7639 |
Posted: 01 Jan 2018 at 8:32am |
It is a French tractor made by Renault as a replacement for the D15 in the late 1960s. Physically smaller in size to a WD, but engine is around 45 hp. |
Sugarmaker
Joined: 12 Jul 2013 Location: Albion PA Points: 8661 |
Posted: 01 Jan 2018 at 9:35am |
Looks like based on your wiring work LED lights will not be a issue for you.
Next size larger tires/rims would look awesome too! Regards, Chris
John WV
Joined: 30 Oct 2010 Location: bunker hill wv Points: 280 |
Posted: 04 Jan 2018 at 12:20pm |
just how many did greenbrier tractor sold? I brought a 160 from a dealer in Lewisburg 5 years ago on rt 219. now its up on the other end of the state in the easten panhandle Now I have 2 of them both are 1970. my dad brought the first one in white post va. now some one posted its about 45 hp. 12 years after dad brought his 160 we had to put in a new 3th gear and he asked them to put it on a dynamometer because he told them that the tractor has more then 40 hp. So they did at 71 hp. it started to smoke and at 73 hp it killed it. I was told that massy rates it at 73 hp.for their tractor. I just wish parts was easier to find.
Lonn
Joined: 16 Sep 2009 Location: Назарово,Russia Points: 29819 |
Posted: 04 Jan 2018 at 12:40pm |
Wink I am a Russian Bot |
BenGiBoy
Joined: 11 Nov 2015 Location: Ashville, NY Points: 705 |
Posted: 04 Jan 2018 at 2:31pm |
What do you have to test out on the LED lights? Looks like any type of lights would be something you could do in your sleep.
'39 Model B
Tractors are cheaper than girls, remember that! |
Flyer
Silver Level Access
Posted: 04 Jan 2018 at 4:40pm |
^I'm working out how rapid and in what type of pattern can I flash the lights for parade duty. The strobe module should be getting here in the next couple of days so I should be able to do a bench test to see if what I have in mind will work with the lights I picked.
An optimist sees the glass as half full. The pessimist sees the glass as half empty. The engineer sees a glass with double the required capacity.
BenGiBoy
Posted: 04 Jan 2018 at 5:19pm |
Oh, that will be interesting! We want a video when you are done now....
'39 Model B
JayIN
Posted: 04 Jan 2018 at 5:21pm |
Sounds pretty cool. Best of the old and the new!
Rp1456
Posted: 10 Jan 2018 at 10:01am |
Very Nice 160, they are fun to restore we re did ours and added some funs things (Turbo, and pump work, nothing crazy) ours is a fun little tractor, a little bouncy in the field, but that can be fixed with tires and weight. Have fun Yours looks super solid ours was a basket case.
Flyer
Silver Level Access
Posted: 10 Jan 2018 at 10:16am |
^That's a nice looking tractor! I like the exhaust stack.
Flyer
Silver Level Access
Posted: 17 Feb 2018 at 9:41pm |
Well, it's finally on its way back together. The engine has been rebuilt and it's sitting on four wheels again. Pics of the project as it continues:
One rebuilt Perkins AD3.152: ![]() Starting to put it back together. ![]() Clutch is installed. It looks a lot prettier than it did when I removed it. ![]() Engine bolted back in place. Getting the two-stage clutch aligned was a little tricky but a little patience goes a long way. ![]() Frame rails and front wheels back in place. I'm happy to have it back on four wheels. ![]() ![]() Still a long ways to go but it feels good to finally get the engine and frame back in place. |
BenGiBoy
Posted: 18 Feb 2018 at 1:46pm |
Lookin' good! Back on 4 wheel means you are getting somewhere at least.
![]() - Ben |
'39 Model B
oldways
Posted: 18 Feb 2018 at 7:13pm |
Looks great. Only problem is now I think I need a 160
CTuckerNWIL
Posted: 18 Feb 2018 at 7:35pm |
I kept an eye out for more than a couple years, looking for a decent 160. A local guy had a rebuilt 3-152 engine with a lot of other work done, new tires rims and paint, with new gauges, clutches, but in a Red and Gray tractor. I bought it.
Now after using it 2 years for bush hog, grading the drive, plowing garden, discing food plots and plowing snow, I want to find me another engine just like it, to put in my OC46 loader. ![]() |
Flyer
Silver Level Access
Posted: 19 Feb 2018 at 11:01am |
I just hope the engine is as reliable post-rebuild as it was before. I made the right call on the rebuild considering what I found on the inside of the fuel tank and what the people rebuilding the injection pump found when they opened it up. However, I'm not going to have it far enough together to fire up until well after it's painted and I really don't want to have to tear into it at that point.
JayIN
Posted: 19 Feb 2018 at 11:03am |
I think that Perkins.is.the.same.one in my 853 Bobcat. You will love.it.!!! Very stingy on fuel.
H Clark
Joined: 11 Jul 2010 Location: West Virginia Points: 404 |
Posted: 19 Feb 2018 at 6:25pm |
Looking good. Can’t wait for another update!
1960 D-12,1948 WC, 1973 160, 1977 175, 1984 6060
Flyer
Silver Level Access
Posted: 18 Apr 2018 at 8:46am |
Spent several weeks cleaning parts, getting organized, and waiting for weather to support a final power wash and sand blast. We had two nice days last week and managed to get it blasted and in the paint booth. It snowed while it was in the booth and cleared off enough to get it back out last night. We were in a bit of a rush to get it moved back to the shop since it's supposed to snow here again today. The plan was to have it on the new tires and rims when it came out of paint but those will be installed in the shop instead. Pictures from the last week of progress:
Post Sand Blast: ![]() ![]() ![]() ![]() ![]() Post Paint: ![]() ![]() ![]() New Rear Tire Progress: ![]() ![]() ![]() ![]() We pushed it into its current spot by hand. If all goes as planned (not the only project in my friend's shop), the next move it makes should be under its own power. |
JayIN
Posted: 18 Apr 2018 at 8:48am |
Nice!!!
AC7060IL
Joined: 19 Aug 2012 Location: central IL Points: 3671 |
Posted: 18 Apr 2018 at 9:21am |
Very sharp! Flyer, in one of your earlier post you mentioned sand blast. Do you sand blast frame & housings only, or everything (engine included?)?
Thanks for sharing photos & follow-ups on your post. I've enjoyed watching your progress. |
Flyer
Silver Level Access
Posted: 18 Apr 2018 at 10:55am |
Thanks! We sand blasted the entire tractor as it's shown in the first picture. I just made sure all of the openings on the engine were sealed really well before we did it. We went from sand blast to primer to paint in five evenings. |
Flyer
Silver Level Access
Posted: 23 Apr 2018 at 7:07am |
New shoes for the back are done. Still have some lug bolts to clean up,
paint, and install. The fronts are next on the list and got a lot of
parts cleaned up and ready for paint. Not a half-bad bit of progress
this weekend.
tbran
Joined: 14 Sep 2009 Location: Paris Tn Points: 3660 |
Posted: 23 Apr 2018 at 9:14pm |
looks like a spin on oil filter... hows that work... what is the pn on the filter housing and filter?
Flyer
Silver Level Access
Posted: 23 Apr 2018 at 10:12pm |
Mine was a canister type but I swapped it over a few years ago. The pieces are in the parts catalog for the 160: Adapter: 72080564 Filter: 71014120 |
Page <12 |
