My truck won't crank
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Topic: My truck won't crank
    Posted: 26 Oct 2018 at 5:17pm
99 GMC, won't crank, stranded at work. Instrument cluster lights up. No crank, no click nothing. Tapped the starter to see if that helped, nothing. It does have security feature, what I am looking at for fix? Thanks Tracy
Bob D. (La) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob D. (La) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2018 at 6:17pm
Tracy, Not that this is the problem but the neighbor called me last summer, her car wouldn't start and she needed to get the kids to baby sitter and go to work. It was doing just as you describe. Tried jumping, nothing. Tried starter trick, nothing. Out of desperation I checked gear shift to insure in park. Sure looked like it was but after moving it out of and back into park, it started.
Grayray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Grayray Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2018 at 6:31pm
Yep, what Bob said, or try putting it in neutral to start it.  Could be the neutral safety switch.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2018 at 6:39pm
I will try that. I think it may be the switch not reading the key.Wish there was a quick test to diagnose it. Thanks Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2018 at 7:59pm
I took the car and drove over to shop. Tried the shift lever in park and made sure it was moving all the way. No click of nothing. Dash, and lights power up. Tracy
truckerfarmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote truckerfarmer Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2018 at 9:21pm
Common problem with GM pickups is pot metal parts wear out and don't fully engage ignition switch. Switch is generally on top of steering column just below dash. If you have a tilt column, try putting it all the way up or all the way down. Depending on whether it is a push or pull switch, that may get it to engage. Simple way to test.
omahagreg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote omahagreg Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2018 at 9:33pm
Does your '99 have two positive cables at the battery? My '96 did, and they corroded.  One went direct to starter, one to fuse box on fender wall.  The second one on that single bolt was not powering up from corrosion, causing all sorts of troubles.  Replaced the cable and bolt, never had another problem.
Greg Kroeker
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2018 at 10:02pm
I will check for cables and tilt the column up and down. Last time it did this was at the farm. Left it overnight and it cranked up like always. Nothing more aggravating than a vehicle you can't trust. I watched a video on removing the switch. Doesn't seem that bad. What I wonder is how to get a switch that is keyed the same as doors. This truck has security and the chip in key fob.Thanks Tracy
DanWi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2018 at 10:33pm
Turn the key on on but don't try to start it let it set for 10 minutes to recognize the key when the security light flashes you can start it. Wife 03 grand am has been doing it more she now starts the car 10 minutes before she leaves for work. It doesn't do it all the time just once in a while.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2018 at 11:19pm
Tracy, the KEY is near the steering wheel... the SWITCH I down by your knee above the column... that's where the electric is....... you don't replace the key or lock, just the electrical switch box.
there is a rod or something tieing the key lock to the switch... make sure the rod is not broken or bent/ etc.
Edited by steve(ill) - 26 Oct 2018 at 11:21pm
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2018 at 5:49am
Yep, been there! Try this, it’s free!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2018 at 5:50am
Oops...hmmm...
Edited by Tbone95 - 27 Oct 2018 at 5:53am
Dave H View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2018 at 5:55am
What Steve said about that switch.  I had to replace eons ago.
Thad in AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2018 at 6:51am
Tracy I’ve had a lot of trouble with my cables on my 99 the past couple years. I replaced the bolts and no more problems.
fixer1958 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fixer1958 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2018 at 7:55am
Is the security light in the dash on with the key in run position. Should come on and go back out if there is not an issue with your key. If it stays on you do.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2018 at 8:50am
The battery light comes on, no security light. Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote fixer1958 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2018 at 9:25am
Likely not the key issue. You need to see if you are getting power to the small wire (purple) at the starter in the crank position. Need a helper. If no power at the purple wire start back tracking. Jump the starter at the starter from the purple wire to battery positive to see if the starter engages. It will eliminate the starter if it engages. If you are sure it won't engage it's the starter.
Didn't say it would be easy but better than shotgunning parts at it.
See what you have and we can go from there.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2018 at 9:30am
No click from solenoid. I tapped on starter. Nothing. Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2018 at 9:50am
Went to shop today, put key in ignition. Did not try to start it. Let the security light blink several times. Started right up. Turned it off and started it 5 times no problem. What is most likely issue here? It is not a good feeling knowing it might strand me miles from home. Thanks Tracy
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2018 at 10:06am
One thing - the starter grounds through internal wiring as does the solonoid .
It's not like the old starters where the solonoid will click .
Brushes in starter are held by plastic lug and if brushes wear down they will not contact armature and starter is dead - as is solonoid . Easy to check brushes by removing end plate of starter .
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2018 at 2:22pm
Replace the starter especially if it's the original one. Yes it could be something else but the starter is a high load wearable part that will fail at some point and even if that is not the issue now, it will be down the road IMHO.😐
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2018 at 4:29pm
Dang, fixer, I forgot all about that procedure.  Was the way I used to do it when a beater was my daily transportation.  Confused
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2018 at 5:14pm
get rid of the 'security' computer if you can...that'd eliminate 99% of the problems.
Steve M Ind View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve M Ind Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2018 at 3:19pm
Check for codes with a good scanner. Security problems usually set codes.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2018 at 5:01pm
When in doubt, wif chebbies, disconnect battery for 5 mins, then reconnect. That's all I know or want to, about chebbies...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2018 at 5:48pm
Last week when it DID NOT START, did you get the security light blinking ?  LIght should blink, then go out and ready to start.. IF you always had the light, then the key was not the problem.. If it NEVER cranked, im still guessing the switch was not sending a signal to the solenoid, or the old starter is worn out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2018 at 7:00pm
Honestly Steve, I couldn't tell you yes or no. I don't know what caused it. It has done it before. Also Sunday I noticed my clock was about 20 minutes slow. Can't figure that out either. Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2018 at 8:32pm
I reread your original post.. Don't think the KEY or PATS ( iginition system) would make it NOT CRANK.... those are NO START conditions... NO CRANK  is no power to the starter, or bad starter... Can be neutral start switch, ignition switch, corroded cables, bad ground, or starter / solenoid bad........... like mentioned, if starter is 20 years old... its time to change even if it is not the ONLY problem.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2018 at 11:02pm
On the wifes pontiac when it goes into security mode it will not crank like it is dead first time it happened to her at work they tried to jump it and it still wouldn't turn over. When she did the reset it starts right up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2018 at 7:33am
I had bought a used Grand Am from my sister.  It had "stranded" them a couple times, mechanics looked at it, never a good explanation, but it hadn't done it in a while, so it was cheap and what the hay.
It did it to me, fortunately in the home driveway.  Me being the frugal type, I did not call a tow truck to take it to the shop, I towed it myself with a strap the 15 miles to the shop.  Mechanic called me the next day, said he went out to look at it, and it started right up perfectly.  Hmmmm.....
Son had turned the key on to steer and listen to music on the way over, inadvertently discovered the reset procedure!
It did it to me one more time before it got totaled.  Never found the "root cause".
