My tractor doesn't stop!
Ron(AB) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron(AB) Quote  Post ReplyReply Direct Link To This Post Topic: My tractor doesn't stop!
    Posted: 17 Oct 2015 at 8:49pm
Came off the field today and my 7000 would not stop when I pushed the fuel shut off. The cable is good seems the governor or fuel linkage in the pump must need an overhaul?
Its been acting strange the last few days revving up by itself when at idle, but this is new, and it would not shut down.
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2015 at 9:05pm
Make sure the shut off lever on the pump moves free. Take off the top cover and make sure the little cam is still in place.
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2015 at 9:06pm
I'm sure it will shut off eventually....
ALLIS EXPRESS!
This year:
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2015 at 9:52pm
Have saw them do that when running low on fuel (getting air). Also if metering valve gets worn or some one polished it.   MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron(AB) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2015 at 9:07pm
I"ll check the pump Ed, thanks.
