My NFE FPS ‘45
captaindana View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Topic: My NFE FPS ‘45
    Posted: 15 Jan 2023 at 5:07pm
Hey my friends I took a ride instead of shop work today, bought anotherHD bench for my new heated shop too. I did take a few minutes while bullying the new to me bench through the doors and ran a compression test on her.   Every cyl shot the gauge to between 145 and 150 psi which I’m confused as I didn’t think they should be that high? Is this kosher? Enjoy every day. Dana
Blue Skies and Tail Winds
                          Dana
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2023 at 5:26pm
That's a new one on me !
How do you run a Compression Test on a HD Bench?
Take FEL and push the Bench up against a wall?
   Any pictures ?
G
           ------- L O L -------
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2023 at 5:26pm
145 is about spot on for M&W pistons. Got an engine kit from Tony years back, it makes about 150.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2023 at 5:53pm
Or OEM D-17 4 inch bore pistons are 145 psi.
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2023 at 7:05pm
If you stick a borescope camera in the cylinder, you would be sure what you have for pistons.
This page was generated in 0.219 seconds.
