My New Toy |
Joined: 11 Sep 2009 Location: illinois Points: 90892 |
Topic: My New ToyPosted: 18 Aug 2025 at 6:02pm |
Got a 9 inch South Bend lathe that i inherited from my dad 30 years ago. Gramps use to run it at the war factory in 1942... Dad rebuilt it in 1980.
15 years ago i bought an old RYERSON that was to be scrapped and rebuilt (repaired) it... 1895 vintage, 22 inch swing.. Yea its a horse and clumsy but gets you within a couple thousandths.. ( it will be retired when the 16 inch lathe is finished) Been looking for a South Bend 16 inch short bed for quite a while. Ran accross this one on Marketplace.. Had to drive 2.5 hours to get it... 1952 model so its NEW compared to what i own. Dirty, but everything seems to be TIGHT... 3 phase 1.5 HP motor so i need to get a VDF or new single phase 1750 rpm motor..... Going to be a winter ( Jan- Feb) project... Tear down , clean, inspect, new belts, maybe bearings... and PAINT. And the straps on the chuck shaft are not TIGHT... just keeping it from tipping over... Straps around the bed for anchor. ![]() Edited by steve(ill) - 18 Aug 2025 at 6:20pm |
thendrix
Joined: 04 Feb 2013 Location: Fairmount GA Points: 5183 |
Posted: 18 Aug 2025 at 6:58pm |
Ah yes, the old belt drive Southbend. We had 4 or 5 at my high school. Mr Dye loved them because if you hit chuck hard enough to break the belt all you needed was a stapler
Posted: 18 Aug 2025 at 7:47pm |
just looked and this one has the taper cut adaptor on the back.. I never really notice that when purchase... also the leather belt is GONE... has a 2.25 inch wide rubber belt with knobs on it, turned inside out so it runs on the SMOOTH SIDE rubber..
similar to a serpentine, but cogs..
Walker
Posted: 18 Aug 2025 at 9:42pm |
The ones with motor in the basement were called underdrives.
Posted: 18 Aug 2025 at 9:56pm |
YEP... motor in the lower cabinet came in the late 1940s.... Before that the motor and reduction shaft were mounted OUT BACK....... Lathes from 1800- 1930 era had TOP MOUNT as they were hold overs from the old ROOF MOUNTED pulley/ shafts from the steam engine days....
This is my 1895 Ryerson with the "UPDATED" top mount beam , motor and reduction shaft.. Original was probably ROOF driven in a big factory.. ![]() |
Posted: 18 Aug 2025 at 10:02pm |
https://www.youtube.com/watch?v=cXDbH5pzagc
7 minute mark shows a good view. Edited by steve(ill) - 18 Aug 2025 at 10:04pm |
Thad in AR.
Joined: 12 Sep 2009 Location: Arkansas Points: 9733 |
Posted: 20 Aug 2025 at 5:57am |
Steve that’s a good looking machine.
Of course your old one is a good looking old beast as well. Can’t wait to see this one finished. |
Posted: 20 Aug 2025 at 9:04am |
got it setting outside the garage door right now.. Spend a couple days cleaning the crud off before moving inside....... guess the first thing i need to do is get a VFD and temp wire so i can test it out and see any potential problems..... guy had 3 phase power and started the motor up , engaged carriage and moved 6 inches.... about 1 minute run time is all i got.. rubber belt is spiced with steel aligator clamp... i could hear that BUMB- BUMP as it ran....... winter project, but need to run an hour prior to that to test EVERYTHING out, before teardown.... got to have a base line for work.
