My new Allis Chalmers D272 hydraulic question.
John426 View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote John426 Quote  Post ReplyReply Direct Link To This Post Topic: My new Allis Chalmers D272 hydraulic question.
    Posted: 08 Jan 2025 at 4:51am
I have just completed my collection of small Allis Chalmers with a D272 model built in England.
When restarting, the hydraulic system is very weak. I only lift 300kg. After dismantling the hydraulic pump, the relief spring is broken. After changing it, I measure a pressure of 220 bars.
This pump is the same as on the C model. Same part number and spring. But I have no information on the hydraulic pressure of the D272 model. I do not have a service manual, only the parts manual.
What surprises me is that the integrated cylinder of the D272 measures 76mm in diameter, or 46 cm², which with 220 bars would gives a force of 9.6 tons and provide a lifting capacity of 1.7 tons.
This effort of 9.6 Tons seems very high for this small tractor and for the frame which is the stop for the cylinder. Isn't there a risk of breaking the lifting frame?
Any information or experiences on this subject?
Edited by John426 - 08 Jan 2025 at 4:52am
TramwayGuy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TramwayGuy Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2025 at 9:44am
Are you measuring the bore diameter or the rod diameter of the lift cylinder? I don’t think there is piston packing like on most hydraulic cylinders, so it’s the rod area that counts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote John426 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2025 at 10:06am
It is the bore diameter 3" . There is no rod , it is not a standard cylinder.
Edited by John426 - 08 Jan 2025 at 10:42am
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2025 at 11:51am
Hi John
For reference only, here is a Link to a picture of the Rear of a D272:
G
https://www.tamarvintagetractors.co.uk/product-page/allis-chalmers-d-272
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2025 at 2:44pm
220 bars converts to 3190 PSI, if I remember right, CA pump was 3500 PSI max, 4gpm flow rate.  Have you checked the flow rate of the pump?
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2025 at 8:10pm
Originally posted by John426 John426 wrote:
... provide a lifting capacity of 1.7 tons...
Just looking at the pictures it would appear that the relative lever ratios will reduce that lifting capacity by a significant amount. 300 kG may not be too far from reality.
