My latest addition to the fleet |
ChuckLuedtkeSEWI
Joined: 11 Sep 2009 Location: Jackson, WI Points: 1826 |
Topic: My latest addition to the fleetPosted: 05 Dec 2010 at 12:57pm |
Went on too long of a roadtrip from Friday night through this morning to go to Nebraska and pick up a D19 from Josh(NE). Clutch is out of it right now, so my goal sometime this winter is to put it in the shop, split it and put a clutch in and then see what else needs fixing. Here are some pictures:
It has a set of these Rowe foundry weights on it. Anyone know how much they weigh?
The rest of the sheetmetal is pretty nice, but the front radiator shroud needs a little work to say the least
It runs pretty nice, just doesn't move at the moment! I am unsure what I am going to do with it at this time. I was thinking of making a puller out of it, and putting the narrow front from my D17 on the front. I don't know if I should just put a regular clutch back in it, or put a button clutch in it, but if that makes it such a pain to use it for anything else, then I will probably just put a regular clutch back in. I have never put a button clutch in a farm tractor yet so I am unfamiliar at how bitey they can be in that application.
I will be looking for a grill screen, grill shroud, and trim panels for under the gas tank. Other then that and the seat, it's just the usual guages etc. and tires when I get that far.
1955 WD45 diesel 203322 was my dad's tractor, 1966 D15 23530, 1961 HD3 Crawler 1918, 1966 D17 IV 83495, 1937 WC 41255, 1962 D19 6221
Claus
Joined: 09 Dec 2009 Location: Hebron In Points: 1166 |
Posted: 05 Dec 2010 at 1:29pm |
Looks like a nice but expensive project. I would leave the wide front on or go with a D19 narrow front. Looks like you got it on the trailer backwards, surprised the rear tires fit between the trailer fenders.
MBolton
Posted: 05 Dec 2010 at 1:30pm |
Very nice, Chuck! The one I picked up in August has seen some use too. I still have a power steering cylinder leak, a noisey hydralic pump to deal with. At some point breaks and front tires. Why didn't God make this addiction lower in cost?
Ken
Lester
Posted: 05 Dec 2010 at 2:40pm |
They weigh from 280 to 320lbs depending on witch ones they are.
darrel in ND
Joined: 22 Nov 2009 Location: Hebron, ND Points: 8759 |
Posted: 05 Dec 2010 at 3:16pm |
Chuck, glad to see that you had a successful trip. I'm kind a bummed out that the weather didn't cooperate so that I could of met you in SD. I did get a lot of work done at home, though. Good luck with your new project, you can't go wrong with a D 19. Talk at ya later, Darrel.
ChuckLuedtkeSEWI
Posted: 05 Dec 2010 at 3:23pm |
Claus, I went a local lumber yard on the way up and got some cinder blocks and some 2 x 10's for ramps. The tires then went over the fenders and the blocks. Worked alright, but I am thinking of instead of fixing the fenders this year, I am going to remove the axles on the trailer, drop them down and make a steel extension for each side of the trailer to make it a deckover style. No matter what I use the trailer for, the fenders are always in the way.
Larry B
Joined: 11 Sep 2009 Location: charter oak Ia Points: 386 |
Posted: 05 Dec 2010 at 6:24pm |
hey chuck sounds like you had a good trip. i am the one that met you with the wheel; did your friend get it yet?hope it was satisfactoty
Dusty MI
Joined: 13 Sep 2009 Location: Charlotte, Mi Points: 5060 |
Posted: 05 Dec 2010 at 6:43pm |
I've seen trailers with removable fenders.
Dusty
norm[ind]
Joined: 29 Oct 2010 Location: bourbon,ind Points: 2992 |
Posted: 05 Dec 2010 at 6:54pm |
we have the panels fro under the tank, grill and usa made gauges
1-800-254-3116 for info. an pricing
Allen Dilg
Posted: 05 Dec 2010 at 8:51pm |
Hello Chuck!! I have made several sets of FENDERS out of 1"x12" STAIR CHANNEL. works very well. Allen
AndrewGubbels
Joined: 12 Sep 2009 Location: nebraska Points: 1518 |
Posted: 05 Dec 2010 at 10:38pm |
I wouldnt mind finding one just like it!!! Great find
Andrew |
Andrew Gubbels
Gubbels Restoration |
GBACBFan
Joined: 11 Sep 2009 Location: Green Bay WI Points: 2662 |
Posted: 05 Dec 2010 at 10:47pm |
Larry, Chuck sent me a note indicating the wheel looked to be in good shape, so I'm sure it is. I'm going to meet up with him in a week or so, but with the trip and the weather he had going out and back, I'm going to let him rest up.
Thanks to both you and Chuck for making the connection on the wheel. As I'm sure you found out when you met him that Chuck is one of the better guys you'll ever deal with.
are genuine." - Mark Twain |
