My dead WD45 last week
R Aiken View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R Aiken Quote  Post ReplyReply Direct Link To This Post Topic: My dead WD45 last week
    Posted: 12 Jul 2010 at 4:22pm
Last week when it was so hot I started on this 45 because it was under a shade tree. I got it from a frend that let the engine get stuck. He did put it halfway in a barn.  I took the head off and one cylinder had a halfinch of rust , another just light rust and two were clean.  In about four houres I had it turning over.  The head had one valve seat pitted real bad, had to have it ground at a machine shop. $30.  I put it back togather with a new head gasket, cleaded the carb, sedement bowl, gastank, points and sparkplugs.  It starter the first try, had to readjust one valve a little. The old gas in the tank would only half of it would burn where I dumped it.  It holds water, good oil presure , no leaks, and the hydrolis works.
 I cant tell what all I did to this tractor because none of it would be aproved by a real mechantic.
 Some pictures
 Now I will have to get the good tires and some fenders off the pile and get it finished.
BobHnwO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobHnwO Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2010 at 5:38pm
Good job Richard!!!
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2010 at 6:34pm
Richard you can fix them the way you want they are your tractors!
I don't post all the off the wall ways I get my tractors back in the field.lol
Good job!!!
Don
olivershagnasty View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote olivershagnasty Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2010 at 6:44pm
Richard - all I want to know is what did you use to cut through the rust in the cylinders?
Shagnasty
Dave(inMA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2010 at 6:47pm
Hey Richard - based on the Build-a-B project, I'd say that you'd qualify as a 'real' mechanic any day!
WC, CA, D14, WD45
Leonard View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leonard Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2010 at 7:17pm
Great job Richard.  I am constantly amazed how well the engineers and designers at Allis Chalmers thought through their designs.  Kinda like a timex watch, takes a licking and keeps on ticking.
Leonard
Post Options Post Options   Thanks (0) Thanks(0)   Quote R Aiken Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2010 at 7:40pm
Shagnasty
I use my gratebig cutting torch.  Warm it up a little and the rust will pup right off. I cleaned the carb that way also. however you have to stay away from the brass .
Chris (swIA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris (swIA) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2010 at 7:50pm
Richard, apparently your standards are much higher than mine when it comes to fenders. Personally, I wouldn't know what to do with fenders that have the back corners. Mine have been long since removed by tire chains.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2010 at 10:10pm
Chris, mine haven't exactly been removed - just sorta folded in on themselves. Not sure what the tractor was used for, but both fenders and the seat were toast when I bought it.
WC, CA, D14, WD45
