My 180D Front End |
Post Reply |
DMiller
Orange Level Access Joined: 14 Sep 2009 Location: Hermann, Mo Points: 30935 |
Posted: 9 hours 54 minutes ago at 6:28pm |
Back when I first got the tractor, late 2005, I worked the extendable front axles loose as were frozen in place, Tie Rods were already loose in Ball Ends so also replaced those and had one Cracked the other loose on spindle steering arms. Bought what could find thru a Local AGCo Dealer and thought received good parts in 2006. No so good as it ends up.
Last few years had issues with Outer Tie Rod ends coming loose in Arms and having to retighten nuts, Cotter pins ended up outside the castle nuts, then noted they were wiggling IN the taper hole in the arm. Pulled loose as was fighting Locust Thorn Flats last week to find the holes wallowed out. Tie Rod Ends are ALL loose in sockets so ordered new tie rods and Steer Arms. Tie Rods came from Reliable Aftermarket Parts and to me appear heavier than the last ones. The Steer Arms came from All States AG Parts, are not simple Castings as my last ones, these are Forged and Machined included the Axle Drift hole to slide the axles in or out. Will grab photos as get it fully apart and back together.
Orange Level Access Joined: 12 Sep 2009 Points: 20341 |
Are you using a 1/2" impact wrench to tighten those tie rod ends into the tapered holes ??
Post Reply | |
