Murphy Rockers |
mgburchard
Joined: 14 Sep 2009 Location: Tennessee Points: 1123 |
Topic: Murphy RockersPosted: 13 Feb 2017 at 7:12pm |
Dave Mitch is liking 4-7 swap cams for bigblock Chevy's currently .
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 55204 |
Posted: 08 Feb 2017 at 6:02pm |
What does panky prefer???
mgburchard
Posted: 08 Feb 2017 at 5:41pm |
Phil have a set of the wc pushrods I prefer the stamped ones with the oval o on side cause they are lighter but the WC ones don't bend as easy
wi50
Joined: 24 Sep 2010 Location: weegieland Points: 1010 |
Posted: 31 Jan 2017 at 1:12pm |
If you want Phil, I probably have a set of push rods from a Perkins that are real close to the Allis 201-226 ones, you can just cut and grind the end to fit. I used them to make custom length ones for my old engine and I probably have morein a box
injpumpEd
Joined: 13 Sep 2009 Location: Walnut IL Points: 5198 |
Posted: 31 Jan 2017 at 7:52am |
Smith bros will make what ever you want, you just have to know how to measure every dimension they need. And if you tell them wrong, you just bought a set of paperweights. I only keep 301/426.
d17brown
Joined: 11 Sep 2009 Location: farley iowa Points: 1737 |
Posted: 30 Jan 2017 at 7:24pm |
do you have push rods for 226 d17
phil
bsallis180
Joined: 29 Jul 2013 Location: Pennsylvania Points: 209 |
Posted: 28 Jan 2017 at 9:41am |
smith bros. copy past link http://www.pushrods.net/pushrods.html
injpumpEd
Posted: 28 Jan 2017 at 9:39am |
I keep them in stock for 301 and 426 from smith brothers. The set of 12 is 276.00. You can order them right from them, but you have to tell them what to build, and that's where I did the leg work, plus I keep them on my shelf. I have them in the stock diameter, so clearance isn't an issue. They are very strong, made of a better material, and thicker wall.
d17brown
Posted: 27 Jan 2017 at 7:12pm |
who sells the heavy push rods and how much are they
phil
NEVER green
Posted: 27 Jan 2017 at 8:38am |
Ive used a set, could feel the extra power, bent 3 push rods second pull, going to buy another set!
injpumpEd
Posted: 27 Jan 2017 at 8:17am |
yep, very nice! Just need to put good push-rods in too, since the more aggressive valve opening will bend stock ones eventually. Obviously, you need to make sure you have adequate valve reliefs in the pistons, since these rockers will add quite a bit of valve lift to an engine that's already close to hitting.
Beirnesy
Joined: 30 Jun 2012 Location: Mid Western Ont Points: 351 |
Posted: 26 Jan 2017 at 11:15pm |
Anyone on here using Murphy roller tip rockers?
1969 220,1967 190DXT,1968 190DXT, LGT's 710,,716
