Muratic acid for cleaning rusty gas tank,,? |
desertjoe
Joined: 23 Sep 2013 Location: New mexico Points: 13769 |
Topic: Muratic acid for cleaning rusty gas tank,,?Posted: 02 Dec 2024 at 8:41pm |
Something else perhaps,,,??
NDBirdman
Posted: 02 Dec 2024 at 9:16pm |
That's what I used before using POR to seal the metal inside. No leaks so far and no rust on inside. The POR when dries is hard as a rock, be careful on the drips if you use it. I cleaned the filter bowl port/threads with a tap, it was hard.
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 25272 |
Posted: 02 Dec 2024 at 9:29pm |
hmm, wonder if screwing in a PLASTIC pipe 3/8" pipe fitting into the outlet would be a good idea ?
DaveKamp
Joined: 12 Apr 2010 Location: LeClaire, Ia Points: 6126 |
Posted: 02 Dec 2024 at 11:12pm |
Joe, mount it on a motor that'll turn it at rotisserie speed. Toss in a soup-can full of old nuts, bolts, nails and screws, and let it roll them a while, then change the angle a dozen times... it'll scrub all the rust out... then vacuum out all the loose rust, give it a slosh-around rinse with a cup of gasoline, let it dry for about 10 minutes, then spray the inside with fogging oil 'till you're ready to mount it.
Les Kerf
Posted: 02 Dec 2024 at 11:19pm |
I've done this several times with a small cement mixer
Thad in AR.
Joined: 12 Sep 2009 Location: Arkansas Points: 9733 |
Posted: 03 Dec 2024 at 6:21am |
Joe I tried every trick known to man to clean the tank on my WC.
Last resort was Muratic acid. It worked wonders. I didn’t leave it in long. I had three boxes of baking soda at the ready. I mixed the first box in a gallon of water. Soon as I drained the Muratic acid I poured in the gallon of water/ baking soda and sloshed it around. I did this 3 times and then a good rinse. Did it on a hot sunny day. The tank looked like new in side. I now have an old cement mixer that I strap tanks to. I pour in some roofing nails and dog chain. Let it spin then turn it and let it spin and turn it and let it spin. |
desertjoe
Posted: 03 Dec 2024 at 7:07am |
OK, Many Thanks for the suggestions,,Guys,,!! I failed to mention the size of the tank,,at 12 gallons. SO,,at that rate,,,how much Muratic acid should I start out with in the tank? I do have my cement mixer that runs at a very low speed. How much Baking Soda/Water mix should I have ready to neutralize the acid? I'ma gonna go ahead and make a plate to seal the gauge opening. I also looked into using a Boat type plastic tank,,but I could not find one with a "Fill Spout" in the correct location on the tank and also in the frame,,,,,
HudCo
Joined: 29 Jan 2013 Location: Plymouth Utah Points: 4078 |
Posted: 03 Dec 2024 at 5:16pm |
i use muratic acid for cleaning tanks alot if it makes a leak then it is on its ways anyday and better to find out now
Thad in AR.
Posted: 03 Dec 2024 at 7:18pm |
Joe I did a 10 gallon tank. 1 gallon muriatic acid and one gallon of water. I’d slosh it around every so often. I only let it soak about 30 minutes. I drained it and flushed with one gallon of water and one box of baking soda. I did the neutralizer 3 times then a good rinse. When it was dry I poured in some gas and sloshed it around. It was shiny inside |
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42272 |
Posted: 03 Dec 2024 at 10:00pm |
When de-rusting and prepping metal I use to use a 5 to 1 ratio of water to acid
The problem is it will FLASH Rust if not dried quickly - |
SyncPil
Joined: 28 Oct 2024 Location: Pittsburgh, PA Points: 12 |
Posted: 04 Dec 2024 at 6:30am |
Muriatic acid can work to remove rust, but it’s very aggressive and could damage the tank if not used carefully. A safer option might be using a commercial rust remover designed for fuel tanks, like Evapo-Rust or a similar product. Always follow safety precautions and neutralize the acid afterward.
