Muratic acid for cleaning rusty gas tank,,?
desertjoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Topic: Muratic acid for cleaning rusty gas tank,,?
    Posted: 02 Dec 2024 at 8:41pm
 I have a gas tank that has some  good amount of rust all over inside of the tank. Can Muratic acid be safely used to remove the rust without eating the tank plumb up? Tank currently has no leaks,,,
 Something else perhaps,,,??
NDBirdman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NDBirdman Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2024 at 9:16pm
That's what I used before using POR to seal the metal inside.  No leaks so far and no rust on inside.  The POR when dries is hard as a rock, be careful on the drips if you use it.  I cleaned the filter bowl port/threads with a tap, it was hard.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2024 at 9:29pm
hmm, wonder if screwing in a PLASTIC pipe 3/8" pipe fitting into the outlet would be a good idea ?
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2024 at 11:12pm
Joe, mount it on a motor that'll turn it at rotisserie speed.  Toss in a soup-can full of old nuts, bolts, nails and screws, and let it roll them a while, then change the angle a dozen times... it'll scrub all the rust out... then vacuum out all the loose rust, give it a slosh-around rinse with a cup of gasoline, let it dry for about 10 minutes, then spray the inside with fogging oil 'till you're ready to mount it.
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2024 at 11:19pm
I've done this several times with a small cement mixer
Thad in AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 22 hours 51 minutes ago at 6:21am
Joe I tried every trick known to man to clean the tank on my WC.
Last resort was Muratic acid.
It worked wonders. I didn’t leave it in long.
I had three boxes of baking soda at the ready. I mixed the first box in a gallon of water. Soon as I drained the Muratic acid I poured in the gallon of water/ baking soda and sloshed it around. I did this 3 times and then a good rinse.
Did it on a hot sunny day.
The tank looked like new in side.
I now have an old cement mixer that I strap tanks to. I pour in some roofing nails and dog chain.
Let it spin then turn it and let it spin and turn it and let it spin.
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 22 hours 5 minutes ago at 7:07am
 OK, Many Thanks for the suggestions,,Guys,,!!  I failed to mention the size of the tank,,at 12 gallons. SO,,at that rate,,,how much Muratic acid should I start out with in the tank? I do have my cement mixer that runs at a very low speed. How much Baking Soda/Water mix should I have ready to neutralize the acid? I'ma gonna go ahead and make a plate to seal the gauge opening.
 I also looked into using a Boat type plastic tank,,but I could not find one with a "Fill Spout" in the correct location on the tank and also in the frame,,,,,Clap
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 11 hours 56 minutes ago at 5:16pm
i use muratic acid for cleaning tanks alot if it makes a leak then it is on its ways anyday and better to find out now
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 9 hours 54 minutes ago at 7:18pm
Joe I did a 10 gallon tank.
1 gallon muriatic acid and one gallon of water. I’d slosh it around every so often. I only let it soak about 30 minutes.
I drained it and flushed with one gallon of water and one box of baking soda. I did the neutralizer 3 times then a good rinse.
When it was dry I poured in some gas and sloshed it around.
It was shiny inside
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 7 hours 12 minutes ago at 10:00pm
When de-rusting and prepping metal I use to use a 5 to 1 ratio of water to acid
The problem is it will FLASH Rust if not dried quickly -
"Challenges are what make life interesting; overcoming them is what makes life meaningful."
