Muffler Install
cjallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cjallis Quote  Post ReplyReply Direct Link To This Post Topic: Muffler Install
    Posted: 09 Apr 2018 at 6:39pm
Can anyone tell me what goes through the manifold and muffler to hold it in place from moving? There is a hole in the top of the manifold where the muffler attaches but it does not go all the way through manifold.
Thanks,
Carl
Larry in NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry in NC Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2018 at 7:01pm
You did not say what tractor you are putting the muffler on, but the hole on the manifold is normally there to bolt through the flange on the muffler if the hole does not go all the way through the manifold.
Post Options Post Options   Thanks (0) Thanks(0)   Quote cjallis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2018 at 8:34pm
It's on a C! Ok yes I thought so.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2018 at 7:33pm
There are supposed to be 2 holes on the side of the manifold.  The one you can't see is probably broken off and rusted.  It will need to get drilled out and the hole re-tapped.  Best to run the tap through the other hole too.    For bolts, use brass bolts only.  The one that does not go through the manifold will need to be cut shorter.
This is on my WD45 ...
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2018 at 6:18am
I believe a C would have only one bolt vs two on a WD45.
Wink
I am a Russian Bot
