MRI
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 10 Dec 2018 at 8:04am
Guess I had better experiences with tight spaces than you all. Buddy of mine I worked on the side for had a river tow fleeting service and every so often would have a barge hull or old tow boat go to leaking, we would drag them out on the bank and cut out the thin steel sheeting eventually welding in new. To finish the job on a barge hull we used 5/16 'Drag Rod' on the INSIDE of the double hull barges, lay on a creeper, start the weld and shove ourselves along in a space 16-22" tall with split bracings every four feet would have to negotiate around. Used string lighting to make it less intense and had a blower at the foot end pushing the smoke out the other end but could not sit up at any time until ran out of rod or needed a break. I would not fit in those anymore, grew a little thicker in the middle!! where back then weighed in at 155# 6'2" tall with a 28" waist.
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Dec 2018 at 9:03am
Mom can't handle them....she's been claustrophobic her whole life.
I think I would be OK.  Been in plenty of tight quarters, never been too worked up during the time.  Can't be much worse than laying belly down, head forward, on the straw walkers in the tunnel all the way to the beater for an hour digging out snow/chaff/dustLOL
ACinSC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2018 at 7:40pm
Open MRI ain't quite as open as I'd hoped , but I made it . Seemed a lot longer than 30 minutes to me . Tech said I did good . Dr appointment Thursday and I will find out what's next . Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2018 at 1:00am
GOOD LUCK!!  the worst is over
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2018 at 4:26am
Thanks I'm ready to feel better
This page was generated in 0.258 seconds.
