Mower / Sickle Bar for WD
1953ACWD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1953ACWD Quote  Post ReplyReply Direct Link To This Post Topic: Mower / Sickle Bar for WD
    Posted: 09 Nov 2012 at 8:34pm
I'm thinking about using my '53 WD to mow with and was wondering what mower(s) did Allis match up with the WDs in 1953?  Is it reasonable to think I might fine a AC mower (as referenced above) in decent shape at a reasonable price?  Thanks!
1953 WD - Grandpop bought new, sold to neighbor in 1965, I bought back in 2001, restored 2021; 1974 175 Gas; 1980 5050 Diesel, w/400 Loader
Bolivar Boy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bolivar Boy Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2012 at 9:16pm
well since the Amish aren't using them I'll bet you there are plenty around just waiting for you to find them, both side and rear mount jobs. They are plenty heavy but unbeatable for hay or stubble.........good luck....
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2012 at 7:53am
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2012 at 7:56am
A 80 or 82 series (also known as the twin drive) 7' sickle would work well on the WD. The R desination is rear mounted, the S is the belly (or side mount) and the T is the trail mount. They are available here in the midwest for $300-$400 (tho its hard to find one that does not need some TLC), don't know how common these mowers are around the east coast. I have an 80R for my D14 and it works real nice and installs quickly. The T model hooks up even quicker. Make sure you have all the mounting hardware if you find one.
Kenny L. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kenny L. Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2012 at 8:05am
Also a no.7 that is twin wheel drive, but I agree that the 80&82 are better mowers. Kenny L.
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2012 at 10:13am
I bought a #3 for $125 came with two sets of mounts the parking stand and original manual. I replaced the pitman stick and it works good. takes about 2 minutes to install. When I was a kid we cut all our hay with one and its a good simple mower. Anyone of the twin wheel drive mowers are better mowers untill you need to get parts to fix it.
Flint23 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Flint23 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2012 at 12:38am
here's a pic. of an 80-s
been there done that, not doing it again...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Flint23 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2012 at 12:44am
Here's an 80-r and 80-r3
KenBWisc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KenBWisc Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2012 at 9:09am
There's a WD belly mount available here in NW Wisconsin for $100.
'34 WC #629, '49 G, '49 B, '49 WD, '62 D-19, '38 All Crop 60 and still hunting!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1953ACWD Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2012 at 9:58pm
Thank you!
rtwfarm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rtwfarm Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2012 at 4:57am
Have several 80r's for sale. Ryan 402-469-1738
mdefelice91171 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdefelice91171 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2014 at 4:24pm
Dont suppose you have a mower still available?
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2014 at 9:17pm
Flint23,
That is an 82S which is, in my opinion, a much better mower than the 80S in that
the mounting is a lot less complicated and when set up right will lift to full vertical
with it's own hydraulic ram.
wdgail View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wdgail Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2016 at 7:01am
can anyone send me a picture of frame mounting bracket.Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote wdgail Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2016 at 7:05am
need  pto shaft drive pulley&frame bracket for 82 s
