Mower Question? |
| Author | |||
Claus
Joined: 09 Dec 2009 Location: Hebron In Points: 1166 |
Topic: Mower Question?Posted: 30 Apr 2012 at 3:21am |
Sorry, not an Allis Chalmers question but I'm sure I will get lots of info here. Starting to think about buying a zero turn mower, not in any hurry. I'm partial to a Grasshopper because of the front mount mower and flip up deck design but the dealer support is terrible around me. Next choice would probably be an Exmark.
Anyways, who make the best zero turn on the market today? |
| Sponsored Links | |||
stray
Joined: 16 Aug 2011 Location: Tipton, Missour Points: 323 |
Posted: 30 Apr 2012 at 4:36am |
I would look hard at Gravely and Simplisty I've talk to a lot of people that have them and non of them could say anything bad. If money isn't a problem then Scag makes very good mower but better hold on to your pocket book.
1969 190XT series 3
ernie(IND)
Posted: 30 Apr 2012 at 7:00am |
I have a cub cadet with the fabricated deck. No problems with it at all. I've had it for 3 years and the starter went out last year, but under warranty and repaired in one day. Everything else on it is fine. I like the fact that you can grease the unit. Mine is a 48" cut so I can get thru the gate to the barn and between some buildings. I got this from a cub cadet dealer, it's not one you will find at TSC or such places. |
B26240
Posted: 30 Apr 2012 at 7:20am |
I had a Dixie Chopper for several years--- very well built and easy to service, however not good on side hills so I sold it and went to a conventional lawntractor with all wheel steer. If all you cut is fairly flat ground a 0-turn will do a great job for you.
Claus
Posted: 30 Apr 2012 at 7:28am |
I do have a large ditch and some hills but I will be keeping my compact tractor and mid mount mower so that will not be an issue.
Richard
Joined: 12 Sep 2009 Location: Springfield, IL Points: 198 |
Posted: 30 Apr 2012 at 8:11am |
I've had a Grasshopper for years and like it because it's easy to service and I like the flip up deck. I run a Scag every week. Me and two others, also Scag, keep about 12 acres mowed. The Scag is really built and I like it also.
Lyle124
Posted: 30 Apr 2012 at 8:57am |
I've got a Bad Boy that I got last year and it's built tougher than any of the others that I looked at, the deck is made of 3/16 welded steel not the pressed tin like most of them and I mow 8-9 acres with it with a 72" deck and works just fine. Lyle
5040 Bad Boy Mower
Claus
Posted: 30 Apr 2012 at 10:20am |
I had some running to do this morning so I stopped in my closest
Deere dealer, they also sell Exmark. Things get pretty confusing pretty
fast. The Exmark has a fabricated deck where the Deere has a 7 gauge
stamped deck. The Deere deck outlet is bigger but the deck is
shallower. The front spindle frame on the Exmark is fabricated and the
Deere is cast. Price and engine choices are close on both. Exmark
product line is way too confusing, way too many models and some of the
models are just little differences in each other. Deere offers solid rubber tires on the front, no flats I guess. Just wanted to do some looking. |
WC Fields(N_ILL)
Joined: 12 Sep 2009 Location: Rockton, ILL Points: 39 |
Posted: 30 Apr 2012 at 12:31pm |
BadBoy is good, Exmark is good, Deere is good, Scag is good, I own a Hustler and have no complaints. The Hustler is built solid like BadBoy. The company I work for builds the PTO clutch so I see many of these in the test lab. I liked the way the Hustler was built so I bought one. Mine is only 60" 23hp and I do 7 acres in 2:15 including 1/4 mile of ditch. Had it about 7 years, works perfect.
37 WC 49 WF 53 WD 67 D15
farmtoybuilder
Joined: 11 Sep 2009 Location: Dresden,Ohio Points: 1457 |
Posted: 30 Apr 2012 at 1:17pm |
Compare apples to apples! Parts and service is main thing to me! I prefer air tires on front castor's. Less bouncing on hard ground as you will be mowing faster! :)
Exmark, Scag or Deere are good units.
427435
Joined: 18 Nov 2010 Location: SE Minnesota Points: 18637 |
Posted: 30 Apr 2012 at 5:29pm |
I've got one of the two Scags that my sons used to pay for their college educations (they cut a lot of lawns). They are very well made and easy to work on. If you've got a dealer (don't really need one for much, if you buy one used), take a look at them.
The ones my boys used were the STHM 3 wheel front deck mower. They aren't the true zero turn, but will trim around a tree without backing up. They are also more stable on a hillside (why I had the boys buy them) and the front deck lets you cut under pine trees better than the zero turns. http://www.scag.com/sthm.html |
Mark
B10 Allis, 917 Allis, 7116 Simplicity, 7790 Simplicity Diesel, GTH-L Simplicity Ignorance is curable-----stupidity is not. |
Chalmersbob
Joined: 11 Sep 2009 Location: Pennsylvania Points: 2122 |
Posted: 30 Apr 2012 at 9:51pm |
If you have a zero turn, keep it on flat land!!
A friend of mine was killed when he got too close to the edge of a pond. Before he knew what happened he was in the pond, under the mower. I talked to another friend at the funeral and he said when he got his zero turn, he ran it into a small creek on the first day. Once they tilt, the upside wheel spins and the front wheels run you down hill into whatever.
BE CAREFUL. Bob Edited by Chalmersbob - 30 Apr 2012 at 9:53pm |
DaveKamp
Joined: 12 Apr 2010 Location: LeClaire, Ia Points: 6124 |
Posted: 30 Apr 2012 at 11:34pm |
On a typical lawn/garden tractor, and compact tractors that do not have independant brakes (common driveshaft brake), the loss of traction on the upside wheel is a dangerous thing.
On a true hydrostatic zero-turn, the upside wheel has no effect whatsoever on the ability of the downside wheel's function. It has it's own dedicated hydrostatic pump and hydraulic motor. I respect your concern Bob- EVERYONE should be careful running ANY machine on ANY surface, but a true commercial hydrostatic zero-turn mower presents no higher risk than any other machine, and because of it's independant operation, is actually much more capable of staying safe, and getting OUT of bad situations, than other types. My 'herd' of mowing-able machines include several IH Cub Cadet garden tractors with 42, 48, and 50" mowing decks (which I never use), and two Dixon 429's (cone-clutch driven). my previous 'big' mower was a Howard Price 72" 27hp diesel-powered front-deck rear-steer commercial mower. My current mower (and the best of all by far) is a Bobcat-Textron 60" unit. I've fitted it with 23-10.50-12 Carlisle-Titan ag-tread tires, filled with propylene glycol and fitted with one 75lb garden-tractor weight on each wheel. Front tires are filled with heavy foam, and I've built a roll-cage with steel canopy, more for protection against sun and getting swatted in the face by tree branches, but plenty strong enough to prevent the machine from rolling over. I've also mounted shoulder-level and foot-level floodlighting to facilitate easy operation at night... yes, it's not unusual for me to mow at night.... I also pull a 1/2t garden-trailer full of firewood to the bonfire for marshmellow roasting. Regarding the comment about front-deck mowers- My experience has been that having the deck out in front presented me with no advantage of mowing under trees, over one under my feet... branches are still in my face (hence the cage). The Howard Price's added length did wind up getting me stuck trying to maneuver on many occasions, where the Bobcat simply pivoted around and drove out... it's just a shorter machine. This Bobcat is by far the most stable and safe mower I've ever operated. I can lift it up, and stand it on the side of the deck and one back tire, and it will ALWAYS fall to a normal upright position... excellent design, to wind up with a center of gravity that low. It negotiates the side incline of a 45-degree ditch... it will slide down sideways, but never tip over. I have no reason to think that any other good commercial unit (Dixie Chopper, Scag, or heavier ExMark) would be any less stable. True commercial mowers come with a hefty price tag... I bought mine used from a commercial mowing outfit. These things have extremely thick decks- the sides are heavy enough to contain rocks, broken blades, and anything else that'd be ejected through a 'consumer-grade' deck. Mine was also fitted with chain-mail on the discharge chute. The top surface of the deck is 3/8" thick... the spindles of lighter decks frequently get bent off-plane, leaving a 'swirly' striped pattern to the cut... heavy decks don't do that. It doesn't wad up grass, and it's easy to clean. I don't get picky about being able to flip the deck up- I just drive the front wheels up a wheel ramp and set the parking brake. True commercial mowers use industry-standard driveline components. HydroGear hydrostatic pumps are one de-facto standard... and wheel motors are pretty universal. This solves lots of problems regarding dealer/parts/support. Which leads to one big comment- Bobcat mowers are EXTREMELY expensive... and most really, really good commercial mowers are. Bobcat's factory people are very nice, but their dealer network is hit-and-miss... and in my area, it's clearly a MISS- my local so-called 'dealer' has NO interest in serving any needs other than his own, and Bobcat wasn't interested in selling direct to me to spare me the insult of dealing with their local so-called 'dealer'. Fortunately, I found that a little research finds all the parts off-the-shelf, with exception of the Bobcat-fabricated parts, which I had no problem replicating in my own shop. Sad that Bobcat is in that situation, as dealer network and customer support is the only real weakness in their product. Edited by DaveKamp - 30 Apr 2012 at 11:39pm |
Steve in NJ
Joined: 12 Sep 2009 Location: Andover, NJ Points: 12071 |
Posted: 01 May 2012 at 6:07am |
I didn't see anyone mention a Husquvarna. How do they stack up to the Exmarks, Scaggs, etc. or they in the same catagory as the Home Depot stuff...?
Stan IL&TN
Joined: 13 Sep 2009 Location: Elvis Land Points: 6730 |
Posted: 01 May 2012 at 7:50am |
Steve,
I've got a Husquvarna lawn tractor. This will be my last. What a POS. It's orange and that's it's only saving grace. Looks pretty.
1957 WD45 dad's first AC
427435
Posted: 01 May 2012 at 9:51am |
I have to respectfully disagree. A front deck mower like the Scag STHM has the deck 3-4 feet in front of the operator while a zero turn has the deck under your feet. When you have a bunch of pine trees as I do, the front deck is a much better choice. It also has better traction in adverse conditions as one can lift the deck and put about 95% of the rig's weight on the drive tires. |
Mark
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42266 |
Posted: 01 May 2012 at 10:52am |
I looked a a lot of units and was going to buy a Dixie unit from dealer in MN (used for $5,000) then looked at the Swisher 60" , was a lot less on cost ($3,100) and might not be a fancy in some things but 3rd year now and other than oil change and replacing one main drive belt last year no problems.
I bought mine at Fleet Farm but see they now handle Huskavarna. Unsure of the why of the change as they had the Swisher for a few years. Friend has a Cub cadet but smaller deck says he wishes he had got the larger one, has had a few problems . Somehow the cost of mowing the grass seems to be out of hand when one has to pay $6,000 or more to get the job done. So I am well satisfied with my Swisher with the 27 HP B&S engine.
Claus
Posted: 01 May 2012 at 3:58pm |
Anybody know anything about the Snapper Pro? They make a front mount zero turn that looks pretty good, don't know if it would be as good as a Grasshopper though.
http://www.snapperpro.com/models/features/6:s800x |
mdm1
Joined: 12 Sep 2009 Location: Onalaska, WI Points: 2720 |
Posted: 01 May 2012 at 4:34pm |
My son and I both have Husky chainsaws and will put them against any other saw!
DaveKamp
Posted: 01 May 2012 at 8:02pm |
I have both small and mature conifers around the northwest perimeter of my farm- predominantly Colorado, Blue, and Norway Spruce. The young trees don't present any issues regardless, but the mature trees have long low branches that obstructed my front-deck mower just as effectively as any other mower... the only one that would 'really' get under there well, was the walk-behind. My other solution is to prune the lowest branches, at least on the downwind side, but I found it to be rather pointless, as the needles did an excellent job of killing off anything that tried to germinate under the tree. I avoid cutting the low branches any more than necessary because they do a good job of minimizing snow drifts in the driveways and barnyards. I've never had traction issues with my ZTRs... this Bobcat only gets hung up when I do something stupid like run it up a steep incline and stab the rearend guard down into the dirt, leaving the wheels in the air. (did that once, learned for life). The Howard Price, being a fairway mower design (four wheels, not a ZTR) really doesn't apply, but having it 'long' made it unmaneuverable in the ditches... even with the 72" deck up, it'd just get stuck where it couldn't turn left or right... even a neutral-steer wouldn't get it out because it was too long to 'swing'. My neighbor had a Grasshopper (predecessor to the FrontMount series they have now) that faced similar situations, and he did exactly as you said- lifted the deck... just to maneuver in the ditch... he got it tangled up every so often (like my Howard Price) and we had to drag it out. He replaced it with a MidMount, and hasn't called me to bring the D17 down since. Now, the place where front deck is REALLY nice... is when you have an area that grows, but can't be driven OVER by the machine... example is a weedy spot along a creek or stream, and areas that wash out... just pull over 'em, and it knocks 'em down. |
DaveKamp
Posted: 01 May 2012 at 8:09pm |
There's LOTS of ZTRs now that are heavier than the 'big box' consumer-grade mowers, but BELOW the 'Commercial' grade machines. There's lots of good machines out there, but what I've seen for these 'middle-road' units, is that they have many of the features of a commercial, but they're using proprietary drive systems, and don't have the heft of a commercial machine. The former situation 'boxes' you in when it comes to maintenance and support, and the latter means you don't get the biggest advantages of the commercial line... and the cost, while being less... isn't significant when you consider the lifespan difference of the machines.
I got lucky- I was in the right place, right time, and bought mine from a commercial mowing company that had depreciated it out, and then blown the Kawasaki. I got the machine on-the-cheap, and brought it back to life with a reasonable investment of time and money. I simply could NOT afford to buy one new, but I got it for much less THEN, than a 'middle-of-road' unit costs now. Many people won't do what I did (buy it busted, and fix it up), but in comparison to the tractors we all work on, an older, true commercial mower really isn't difficult or expensive to rebuild. |
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8981 |
Posted: 01 May 2012 at 9:17pm |
I got an early Simplicity Derby 51in (05-06 it's green made by another name which Simplicity owns) last year for $1000 with a blown engine @ 300+ hrs..Solid ,well built. Stuck a new $1400 25hp Koehler(what it had)on it and is much more a mower than I expected.Go fast and cut good. What used to take 2.25hrs cramming the 7016 hydro w/48in deck I breeze through in 1 hr.It's odd and awkward at first but it quickly grows on you and you actually have fun mowing.Mowing around obstacles becomes an art form. ZIP,ZING,ZOW!!!
TexasTrevor
Posted: 01 May 2012 at 9:28pm |
I work at a hardware store that sales exmark and snapper zero turn mowers. The snappers are well built machines but personally I don't think that you could go wrong with a lazer Z exmark or a quest as long as you got one with the fabricated deck.
This aint no rag it's a flag, and it stands for the USA
Hurst
Joined: 11 Sep 2009 Location: Midway, Ky Points: 1220 |
Posted: 01 May 2012 at 10:07pm |
The biggest turn off for the exmark mowers was the fact they don't have greasable deck spindles. We got a Dixie Chopper 27hp 50" cut silver eagle for the farm last year. So far seems like a good mower. Before we had a woods mowin' machine with the Kubota diesel, and that thing was a good mower until a hydro went out and it as going to cost 3,000+ for 2 new hydros. Diesels are getting way overpriced in my opinion, as I believe many of the commercial air cooled gas engines can last as long as the mower chassis with proper maintenance. Also, pay attention to how the hydros are cooled and the reservoir. Heat exchanger and a metal reservoir beat a plastic tank and fans on the pumps in my opinion.
Hurst |
1979 Allis Chalmers 7000
5800 Hours |
Claus
Posted: 01 May 2012 at 10:34pm |
I have been looking at the Woods Mow'n Machine FZ28K (front mount mower, 28 HP Kawasaki), I know it a Grasshopper with orange paint but like I said earlier I like the Grasshoppers. There are a couple Woods dealers in my area, that is why a Woods is more appealing to me than a GH, don't need to go on a hour and a half run for a belt or something, know what I mean?
Hurst how long did your Woods last before the hydro headed south? http://www.woodsequipment.com/productDetails.aspx?id=37 Edited by Claus - 01 May 2012 at 10:36pm |
427435
Posted: 01 May 2012 at 10:45pm |
I don't think you are familiar with the Skag STHM mower, so here's a picture: ![]() My back yard is circled with several rows of pine trees that have grown together. With the STHM, you can stick the deck under the branches, back up, and move to the next tree and stick the deck under that. Meanwhile, the operator is a long ways away from the branches. You can't do that with ZTR as you are sitting higher and partially over the deck. Just mowed around the pines this evening. The unit is over 20 years old, has 2600 hrs on it, and is on it's second set of drive tires (first ones wore smooth and had no traction). I've had to replace the cam in the Kohler engine, but none of the mower parts (except blades and belts) have needed replacing or repair. That includes all the hydrostat parts. |
Mark
ACmowerguy
Joined: 20 Apr 2010 Location: Winfield, MO Points: 1210 |
Posted: 01 May 2012 at 11:39pm |
Ferris is another option. The Snapper Pro is basically a Ferris Chasis without the "independent-Suspension." Dad has a Ferris with the suspension. It rides well but you do still feel some bumps. I would like try running it side by side with the Deere and Hustler to see if its really any better.
