Unofficial Allis Homepage
Mower for Allis Chalmers D17
jeffgarc12 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jeffgarc12 Quote  Post ReplyReply Direct Link To This Post Topic: Mower for Allis Chalmers D17
    Posted: 16 Sep 2020 at 8:52am
I have a old mower for my allis chalmers D17 and it has been converted to have a three point hitch on the snap coupler tongue. However, when I hook the mower on the tongue of the snap couple sticks out to far that I can't lift the mower up very far and also the mower is too close to the tires and hits them. Is there a way to move the mower back or am I doing something wrong.
Acdiesel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acdiesel Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2020 at 11:05am
can you get any pictures posted so we can see what your set up looks like?
sound like something is weld up in the wrong place when the 3-point adapter was installed (maybe)
D19 diesel,D17 diesel serIII D14 NF D14 WF, D15 ser II,
D15 SER.II DIESEL two 720's
dads
D17 ser.4, D14 oliver 77
Gmc trucks,caterpillar
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2020 at 7:55pm
Sounds like your conversion hitch is for a CA, D10/12 instead of the larger tractors.
If it was fun to pull in LOW gear, I could have a John Deere
Post Options Post Options   Thanks (0) Thanks(0)   Quote jeffgarc12 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2020 at 9:34am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acdiesel Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2020 at 10:44am
looks like your lift arms are to short, can't quite tell, but you need about 5 more inches in length.
you can try drilling new holes in the flat stock on the bottom of the draw bar and moving everything back.
Dan
Edited by Acdiesel - 17 Sep 2020 at 10:44am
dads
Scott B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Scott B Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2020 at 2:51pm
I had a similar issue with some implements and my D17. Started using a quick hitch to push the implement back from tires 6”-8”
D17 Series 1
Allis B- 1939
Allis B- 1945
