Movin' Snow with the WD 2/25/10 |
Brian G. NY ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: 12194 Points: 2269 |
![]() ![]() ![]() ![]() ![]() Posted: 15 Mar 2010 at 2:50pm |
Don't mean to remind everybody about the big storm now that the greater part is gone,
but I just sorta figured out how to post a picture.
omahagreg ![]() Orange Level Access ![]() Joined: 11 Sep 2009 Location: Omaha, Nebraska Points: 2806 |
Looks like it makes a nice pile!
Greg Kroeker
1950 WD with wide front and Freeman trip loader |
We had over three feet of snow in two back to back storms on 2/24 and 2/25.
It was all very heavy wet snow.
To give some perspective; in the background to the right and just above my head is
my Dodge pickup and on the other side of it is my D-17.
Left, not right!
Goose ![]() Orange Level ![]() ![]() Joined: 07 Oct 2009 Location: Melrose, Wis Points: 2471 |
Brian,
It looks like your chains are nice and secure. How do you keep them on?
I plow with my WD and a bucket, but my chains keep coming loose. I even have them secured on both sides of the tires with bungee cords. Maybe it's because I have to plow on a steep slope and frequently spin the wheels.
Goose,
I used to have a real nice set of good spring tighteners on the outside of the wheels.
However, since I use my WD in the woods for skidding logs, I kept tearing them off when I rubbed up against trees. I found that if I tighten the chains as tight as I can every time I see any slack, I have no problem. Believe me, I do a lot of work on side hills and I also do a lot of spinning. I believe that the cross chains have to be fairly long so that the side chains stay down on the sidewalls. Contrary to what a lot of guys have said, I have no problem with these "ladder" style truck chains slipping down between the bars.
I attribute that to the style of tire I have; with fairly angular tread.
These chains are fairly well worn and I break a cross chain now and then.
A couple of years ago a friend of mine gave me a brand new set of truck chains that were the right width but a little too short. I was able to lengthen them and find a few more new cross chains to make up a set to fit the WD.
I just can't seem to talk myself into using them as I might "get them dirty". LOL
