Mounting 500 loader
Big Allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Allis Quote  Post ReplyReply Direct Link To This Post Topic: Mounting 500 loader
    Posted: 09 Aug 2024 at 10:44pm
Allis Chalmers Experts,
I have a used 500 loader that I just scored for my 180, just for using around my property. My question is - I see how the loader hooks under the rear axle, is the front of the loader just attached by the bolts on the side plates? I ordered an official manual that will hopefully help but will not be here for a week and I want to move it this weekend. Any advice is appreciated. Thanks.
orangereborn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangereborn Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2024 at 1:09am
YES...
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2024 at 6:27am
The short answer is yes.
As you can see in orangerborn's picture, there are several holes in the side of the loader mounts where it bolts to the frame. Some of the larger holes are for existing bolt heads that protrude through the tractor frame. I believe the bolts you will need are 5/8" diameter.
There is a large "U bolt" that goes around the rear axle housing on each side.
There is also a cross brace that goes across the top of the loader frame 0ver the hood.
Dave (NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2024 at 8:57am
This may or may not help, but it is a 500 loader mounted on my D17.
Do not argue with an idiot. He will drag you down to his level and beat you with experience. Mark Twain.
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2024 at 9:26am
Cross braces top and bottom are very important
nonetheless ,still dead.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2024 at 4:08pm
Found this 180 with loader for sale.
Has plenty of Close-up pictures of Loader.
G
https://www.schneiderauctioneers.com/auctions/9437/lot/2070-allis-chalmers-180-gas-tractor-w-loader
