More IB Questions
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Topic: More IB Questions
    Posted: 01 Jan 2017 at 8:30pm
Where is the amp meter/ignition box suppose to go on an IB? Can someone post a picture of where it goes please?
I'm having some difficulty with the starter as well. Is there a specific starter for the IB? Seems it should be like a CA or late B version where the switch is on top of the starter and you pull a lever to engage it verse pushing it like most. How is this pre-war IB starter suppose to be set up? Anyone have pictures of that as well?
Can't fix stupid
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2017 at 9:55pm
AJ, the box is the same as the B and located at the bottom of the steering post. The starter rod is low and to the right in the photo. Not real clear, but you can see if you look close.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2017 at 10:02pm
Here is another tractor with the starter rod mounted high - switch on top
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2017 at 10:22pm
Help me with this then because there don't seem to have ever been one here.
Can't fix stupid
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2017 at 10:23pm
Another view
Can't fix stupid
shameless (ne) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless (ne) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2017 at 11:27pm
Steve....isn't that steel box in the first pic....a shin banger/scraper? whew!
GreenOrange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GreenOrange Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2017 at 11:37pm
AJ, The battery box is mounted completely different on the pre-war IB's, and the electrical box is mounted to it - notice the difference in throttle control position.  As for the starter switch, it is mounted below the starter, not above.  For the most part, yours looks right.  I'll see if I can dig up some pictures.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2017 at 9:10am
From what information I found over the years when doing my IB over about 7-8 years ago, the Battery box was normally mounted right on the left fender like in Steve's picture. Now the IB could be equipped with a lot of attachments. Mine originally had a Sickle bar on it, so the Battery box I was told and seen pics of it would mounted on the right frame rail. My Battery box (what was left of it) was mounted on top of the frame rail on the left side in front of the left fender. But the box that was mounted there was home made. When I purchased a new Battery box, I went to the right frame rail and the holes in the new box lined right up with two holes that were in the right frame rail perfectly. So I assumed, the original box was mounted there like it was supposed to be, so I remounted it there. I added a Battery shut-off and other things, but that's my own add-ons.
As for the Starter rod, in your pic, the Starter rod is hanging there like where it is in Steves picture. On my IB, mine was in the same spot. It was tough trying to get to it with my work boots on or reaching for it, so I made my own rod, put a 90 degree bend in it and put a ball on it. Makes it a bit easier to get to above the pedals. I also fabbed a support bracket at the tranny to keep it level. You can see in the pic where the Battery box is. Even though I don't have the Sickle bar, I decided to mount the Battery on the right frame rail anyway to keep it close to the Starter motor.  Hope this helps.
Post Options Post Options   Thanks (0) Thanks(0)   Quote GreenOrange Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2017 at 7:49pm
Here's a pic of how the battery box is mounted on the 39 & 40 pre-war tractors.  Same location, different mounting method.The two studs on the right side of the box are where the electrical control box (ammeter, light switch) would be mounted.  This tractor was converted to 12V (that's why the end of the box was cut-out.  I don't have a decent photo of the starter rod or generator setup, but its a straight line from that bracket on the trans to the switch under the starter.  To do this one back to the way it left the factory, an early A-C dealer parts catalog would be a huge benefit, as it will show you almost all the items you are seeking - for yours, look at the parts listed as IB prior to B55301.  It's shocking to see just how many parts are unique to these earliest tractors.  The last of the pre-war IB's (1941 run serial B55301 & up) have a battery box and control box setup very similar to the post-war tractors, shown in the other posts.  For some nice pics of pre-war IB's at work, take a look at this link.  http://cdi.uvm.edu/collections/search.xql?term1=ib&start=0&rows=25
Take note of the headlight mounting too - that's how yours would have been mounted.
Edited by GreenOrange - 02 Jan 2017 at 8:02pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2017 at 8:34pm
I didn't like the battery box on the left fender or the right side frame so I decided to build a battery box and tuck it inside the frame behind the starter. Sat low enough that I can pull the starter out OVER the batter box........ I bought the smallest 12 volt 550 amp/hour battery I could find.
Post Options Post Options   Thanks (0) Thanks(0)   Quote GreenOrange Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2017 at 9:46pm
That is really a slick location for the battery box - looks great and opens up visibility.  Nice work!
Bob-Maine View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob-Maine Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2017 at 8:00am
Fellas, Thanks for all of the above. I have a pre war IB and the info and photos will be a huge help when I get to restoring it (probably years from now). I printed all posts as I know I will not find this when I need it but it will be filed in my shop filing cabinet. Bob@allisdowneast
I used to think I was indecisive, but now I'm not sure.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2017 at 7:39pm
A side shot of my Battery box on my IB. I also installed a shut-off switch and hour meter in the box lid. My IB is 12V. You can see the ground cable at the bellhousing.
