More Deep Plowing
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Topic: More Deep Plowing
    Posted: 12 Feb 2013 at 3:22pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2013 at 3:26pm
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2013 at 4:13pm
It doesn't seem right to cover up that nice black topsoil with all that sand!
woodbutch View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote woodbutch Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2013 at 7:34pm
This looks like a pretty serious operation! So can you tell me why you would turn productive soil deep enough that it no longer can be?
Randaleky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randaleky Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2013 at 7:33am
i really want to hear the reason why also. good looking black dirt going under.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2013 at 12:29pm
I think it's for drainage in soils that are high in organic matter, like peat.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2013 at 12:48pm
Evidently the sand layer is washed or blown in material which is separated by a layer of clay or hard pan that does not allow water to percolate out of it .
 So a wet heavy layer is above the clay layer - then sand below - then another restricting layer.
 Looking at the sand layer it looks like what is called modeled soil - sand or granular material that is stained with materials that were suspended in water - leaving the dissolved deposits behind as water slowly left soil.
 It can be a tell-tale sign of seasonally high water table or of old lake-bed or flooded area. If one encountered this while designing a drainage system for septic system - you could not install it in this soil.
Edited by Coke-in-MN - 13 Feb 2013 at 12:54pm
Ian Beale View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ian Beale Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2013 at 5:24am
There have been a line of limited production Cats coming into Australia from Californian irrigation deep plowing IIRC correctly.  They're aimed here at cutterbaring/ blade plowing (root plowing I think it is called in US.
Tricked up in power and transmissions - I think they have D8 labels but are about D9's.
I can't seem to grab a reference for more info just now.
birdfarmer2199 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote birdfarmer2199 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2013 at 6:41pm
I too would like to know more. Is the sand layer farely consistent throughout the field? Why not shallow up the plow to run just an inch or two into the sand and then leave the third dozed parked?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2013 at 2:47pm
Look closely at the pictures of the sand - you will see brown or gold coloring in it . This means water has stood in the sand and either slowly evaporated or percolated into soil, but at such a slow rate the dissolved material in the water stained the sand.
 This means a seasonal high water table that stands for a long time or continuous saturation of the soil. Below the sand layer there is more than likely another restriction that keeps the water in suspension above it .
 I did a percolation test in soils similar when designing a septic system for a church. It was raining lightly while doing the testing and water did not go down in my test holes but rose as the water in the soil flow across the sand layer seeking it's level rather than sinking into soil.
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2013 at 10:58pm
Wouldn't it make more sense to use a 5' single shank ripper on a big crawler?
Allis Express participant
