more D19d questions
ACscott View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACscott Quote  Post ReplyReply Direct Link To This Post Topic: more D19d questions
    Posted: 08 Dec 2011 at 6:10pm
The engine shop just called me with some more bad news the oil pump was already welded once before and its cracking again, they said i would be better off putting in a new one, my question is where can you get one. is it the same as a gas D19? also they said they need some bolt that goes in the cylinder head to hold the rockers on that is hollow for lubrication, is there such a bolt in this engine ? I cant remember, thanks
Edited by ACscott - 08 Dec 2011 at 7:04pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2011 at 7:56pm
You're probably just going to have to get a used one. From what I was told when I overhauled my 262, the oil pumps were quite robust. I only replaced mine because the "ears" that the bolts go through were broken off and welded back on. There is also a later design that has a relief valve in the outlet. Aside from that, they should be the same. I should know this for sure, but I don't remember there being a special bolt for the rocker shaft. I'd like to say the one of the stands was larger so the oil flowed around the bolt.
Chris/CT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2011 at 8:07pm
Are they similar to D-17D pumps? i have one if it would help. Have 230 buda/WD45D pumps also, brazing on tabs though.
I have the "Stud" that carries oil thru for the 230 buda 6 cyl engine, NOS. Probaly noot the same, I can post part number if you want to check numbers.
Edited by Chris/CT - 08 Dec 2011 at 8:10pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACscott Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2011 at 8:21pm
Chris that would be great if you could post the part number. Others opinions would still be appreciated about this bolt, maybe there is no such thing in the D19 you guys have a lot more knowledge than me.
D-17_Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D-17_Dave Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2011 at 8:25pm
There is a bolte that holds the rocker assembly that is hollow that carries the oil to the rocker shaft.
Travis(NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Travis(NE) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2011 at 8:44pm
The bolt for the rockers is actually a stud with a grove cut the whole length as an oil path. There is usually two of them and they serve as the valve cover hold down points.
As for the oil pump the 230/WD45D is different. The gas and later D17's with the relief would be the same.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACscott Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2011 at 9:00pm
Dave or travis on agco parts books are these studs part# 7450861 ? thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Travis(NE) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2011 at 9:12pm
I am on my iPad at the moment away from all my other resources and AGCO parts books online doesn't work with iPad. I can look tomorrow for you unless somebody beats me to it.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2011 at 9:31pm
To keep from breakeing the ears off the oil pump, drill holes in bolt heads and snug them down then wire them.
  I'm sure I have some oil pumps, will look in the morning if you want one. Does yours have the relief valve in the line?  MACK
nevans View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nevans Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2011 at 9:47pm
If mack doesn't have one we do just let me know 1 618 282 2477 or 282 2048 at night niel
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACscott Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2011 at 10:44pm
Does anybody have the 2 studs i need to hold the valve cover on that travis talked about?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2011 at 4:21am
The D-17 pump I have is later D17 w/ relief, looks like you have plenty of availability there. If those studs w/ groove are same part number, I should have 1 possibly 2 if that helps.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Travis(NE) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2011 at 10:47am
I stand corrected the studs are only grooved part of the length. Correct part#74508061
KenBWisc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KenBWisc Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2011 at 11:31am
A groove can be put into rocker arm studs without the groove with a cutoff tool. Just get the right diameter/length and tread and cut them in.
'34 WC #629, '49 G, '49 B, '49 WD, '62 D-19, '38 All Crop 60 and still hunting!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2011 at 4:09pm
I have one NOS #74508061 stud, probably find another used one. Advise sounds good on the "groove" milled on site to regular standard stud, assuming length is the same? Will need to clean-up threads if done with a cut-off tool.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2011 at 6:00pm
I have both oil pumps. Let me know. 660 828 4310   MACK
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2011 at 6:10pm
when you get a pump - remember - and this is important - on at least some of these units if not all the 'ears' do NOT touch the block - Better check I think they torque to something like 20 foot lbs.   I have seen many pumps with brazed 'ears' before finding this out. .
TomMN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomMN Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2011 at 6:34pm
This is that bolt on a WD45 Diesel using the starter to spin it over to get some oil pumped through lines.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACscott Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2011 at 10:58pm
Thanks everyone for their input and thanks to tom and travis for the pictures, mack if i cant find a pump in canada i will let you know.
This page was generated in 0.119 seconds.
