More D17 wide front questions
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Topic: More D17 wide front questions
    Posted: 13 Dec 2010 at 7:15pm
This wide front that I got had been damaged at one time.   I knew that when I bought it, as the one spindle support was cracked and had to be rewelded together which the guy I bought it from did.   Whatever damage was done, must have been something major as not only was the piece that we were talking about last night was broken, probably from the impact, but also the spindle support as well.   Tonite, as I was getting everything together, I noticed some play in the spindle that was repaired.   What I noticed was that when the spindle arm was moving back and forth, the spindle wasn't moving as much.   As I took it apart, I found the keyway slot is loose on the spindle itself, and the key is bent some.   Is that key supposed to be a regular halfround key, or is it supposed to be thicker on the back of the rounded part and straight for the slot for the spindle arm?   Also, I looked on the AGCO parts book site, and in the picture, there are spindle support bushings.   Do these just go on the bottom or does one go on the top as well?   I don't see on in the top of mine, so I was wondering if it was taken out when repaired and never put back in because the spindle doesn't line up properly from top to bottom from the repair.   I guess I might have to find a whole other spindle support and spindle assembly but I dont' know if someone is willing to sell just those parts.   I don't even want to know if new ones are available from AGCO and if so how much.
Edited by ChuckLuedtkeSEWI - 13 Dec 2010 at 7:16pm
1955 WD45 diesel 203322 was my dad's tractor, 1966 D15 23530, 1961 HD3 Crawler 1918, 1966 D17 IV 83495, 1937 WC 41255, 1962 D19 6221
Matt MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt MN Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2010 at 8:25pm
I believe Stiener sells those spindles, I have not had any apart yet but I would think that there would be a bushing on the top and bottom?
This page was generated in 0.049 seconds.
