More D14 newbie questions
jtheise4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jtheise4 Quote  Post ReplyReply Direct Link To This Post Topic: More D14 newbie questions
    Posted: 05 May 2011 at 6:26pm
Hi guys.  Sorry for all the newbie questions, but I'm still learning and could use some more help.  On my 1958 D14, are the hydraulic pump and power director resivours the same?  In the owners manual, it list two filler holes, but when I look at the actual housing, they sure appear to be one piece.  I do notice there are two drain plugs on the bottom side, so maybe its one housing with two cavities?  Also, can someone please post a picture of the transmission drain plug?  I looked around for it, but there is 50 years worth of dirt and grime under the tractor and I'm having trouble locating the plug amongst it all!  Last question, I see where the final drive filler drive filler plug is, but where is the drain plug?  Do you just pull the filler plug and then evacuate the fluid using a suction gun?  Thanks in advance for the advice.  This site has been an amazing source of information.
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2011 at 8:45pm
bump
BIG MIKE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BIG MIKE Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2011 at 8:49pm
No they are seprate.
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2011 at 9:49pm
Ypu should have seperate resevoirs for the PD and Hyd. Not near mine rite now, but I think the PD dipstick is on the right side (a large cap on it) and the Hyd is on top by the tranny (a 1 or 1 1/8" nut). There should be 3 1 or 1 1/8" drain plugs under the tranny area to drain the fluids. If no one come on and corrects my failing memory, I will check my manul tommorrow and update you.
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2011 at 7:18am
I always figured you were suipposed to take off the final drive pans to clean them out, replace them and then fill them.  Probably when they were new you just added fluid as needed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jtheise4 Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2011 at 8:25am
Thanks for the quick answers, except for the 'bump' comment...not sure what that means.  I appologize for the 'basic-ness' of these questions.  I have the owners manual, but sometimes its not overly clear.  This tractor is twice as old as I am, so a lot of the systems are unfamiliar to me and very, VERY different from my 2010 tractor.  Anyways, appreciate everyone taking the time to help me out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BIG MIKE Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2011 at 9:24am
The reason for the bump was to keep your post up top.He was not making comment about you just helping u out.I know what You me though the first time I saw bump on here i wondered what in the world is this.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jtheise4 Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2011 at 10:05am
HA!  HA!!!  I understand now.  At first I thought maybe my question was so silly that the poster bumped their head!  Thanks for clearing that up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BIG MIKE Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2011 at 12:08pm
Took me a while to figure it out I saw alot of people doing it.And I thought this has to mean something because the people on here are not rude and are very helpful so after awhile I figured it out.
