Moral carburetor |
Post Reply |
jlogli
Orange Level Joined: 12 Oct 2011 Location: Stockport, IA Points: 856 |
Posted: 01 Feb 2023 at 7:15am |
I was wondering, is there a special tool that takes out a needle see on a Maverl carburetor? It looks like it may be a big white screwdriver would work, but having trouble trying to find one. Any ideas? Thanks.
1945 WC on full steel, WD wide front, WD45 power steering, 1966 D-17IVfactory 3 point.1967 D-17IV SC. 1973 rotobaler white top. orange top roto, model 90 combine,82S, four bottom plow.302 baler.
MACK
Use a sickle section or a harden piece of metal that will fit the slot. MACK
Orange Level Access Joined: 11 Sep 2009 Location: illinois Points: 80173 |
might boil the carb in hot water to help loosen up if it is TIGHT.
IBWD MIke
Orange Level Joined: 08 Apr 2012 Location: Newton Ia. Points: 3642 |
Thanks(1)
Facing this trouble years ago I found an old screwdriver and ground it to fit. Works darn good. |
Steve in NJ
Orange Level Access Joined: 12 Sep 2009 Location: Andover, NJ Points: 11744 |
Mike has a good idea. To remove stubborn seats for the needle valve, I use a GM brake spoon for adjusting brakes. Fits in the slot nice n' snug, and if you need a little extra torque on the real stubborn seats, I put my small adjustable wrench on the blade and get a little more leverage. Make sure you have the body of the Carb firmly anchored in the vise. Don't ask me how I know that....... If you have to tackle getting the nozzle out, (which can be a real bear sometimes) I took a large screwdriver, test fit the blade in the jet slot on a spare nozzle, then I ground the sides of the blade down till it fit nicely into the cavity without hitting the threads, and crank the nozzles out ever so slow. A screwdriver with a square shank is a plus just in case ya gotta' git' that small adjustable back out again to crank a stubborn nozzle out. The only time I have an issue trying to get a nozzle out is if somebody already been there and totally screwed up the jet slot. Now you have a REAL problem goin' on....! Steve@B&B
DaveKamp
Orange Level Access Joined: 12 Apr 2010 Location: LeClaire, Ia Points: 5724 |
All of the above suggestions! I have a couple ultrasonic cleaners, and I use Il Steve's boil trick after I've had the Ultra sing to it for a while (all the fine crud flows out). If they're still stuck in, I put 'em in boiling water for about 15 minutes. Wear appropriate hand protection after you lift 'em out, and hold them good and solid, use a tool ground-to-fit-tight.
David Maddux
Orange Level Joined: 13 Sep 2009 Points: 2518 |
Someone makes a screwdriver for this. I have one, will have to look and see if a name is on it.
jlogli
Sweet!
Ed (Ont)
Orange Level Joined: 08 Nov 2009 Location: New Lowell, Ont Points: 1255 |
Thanks(2)
Really had me wondering when I saw the heading about "moral carburetor". Lol.
Post Reply | |
