Moral carburetor
jlogli View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jlogli Quote  Post ReplyReply Direct Link To This Post Topic: Moral carburetor
    Posted: 01 Feb 2023 at 7:15am
I was wondering, is there a special tool that takes out a needle see on a Maverl carburetor? It looks like it may be a big white screwdriver would work, but having trouble trying to find one. Any ideas? Thanks.
1945 WC on full steel, WD wide front, WD45 power steering, 1966 D-17IVfactory 3 point.1967 D-17IV SC. 1973 rotobaler white top. orange top roto, model 90 combine,82S, four bottom plow.302 baler.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2023 at 8:05am
Use a sickle section or a harden piece of metal that will fit the slot.                      MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2023 at 8:26am
might boil the carb in hot water to help loosen up if it is TIGHT.
IBWD MIke View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2023 at 9:07am
Facing this trouble years ago I found an old screwdriver and ground it to fit. Works darn good.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2023 at 5:50pm
Mike has a good idea. To remove stubborn seats for the needle valve, I use a GM brake spoon for adjusting brakes. Fits in the slot nice n' snug, and if you need a little extra torque on the real stubborn seats, I put my small adjustable wrench on the blade and get a little more leverage. Make sure you have the body of the Carb firmly anchored in the vise. Don't ask me how I know that.......
If you have to tackle getting the nozzle out, (which can be a real bear sometimes) I took a large screwdriver, test fit the blade in the jet slot on a spare nozzle, then I ground the sides of the blade down till it fit nicely into the cavity without hitting the threads, and crank the nozzles out ever so slow.  A screwdriver with a square shank is a plus just in case ya gotta' git' that small adjustable back out again to crank a stubborn nozzle out. The only time I have an issue trying to get a nozzle out is if somebody already been there and totally screwed up the jet slot. Now you have a REAL problem goin' on....!
Steve@B&B
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2023 at 9:50pm
All of the above suggestions!  I have a couple ultrasonic cleaners, and I use Il Steve's boil trick after I've had the Ultra sing to it for a while (all the fine crud flows out).  If they're still stuck in, I put 'em in boiling water for about 15 minutes.  Wear appropriate hand protection after you lift 'em out, and hold them good and solid, use a tool ground-to-fit-tight.
David Maddux View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Maddux Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2023 at 8:04am
Someone makes a screwdriver for this. I have one, will have to look and see if a name is on it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jlogli Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2023 at 11:24am
Sweet!
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (2) Thanks(2)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2023 at 5:39pm
Really had me wondering when I saw the heading about "moral carburetor". Lol. Smile
