Model G sickle mower
MStevens View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MStevens Quote  Post ReplyReply Direct Link To This Post Topic: Model G sickle mower
    Posted: 05 Feb 2020 at 10:04pm
I recently purchased a 1948 Model G and was given 2 sickle mowers along with it. I am looking for info on rebuilding the mowers. Bearing info, etc.. From what I can tell by pics online I think I have the No. 4 model. Would greatly appreciate any help.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2020 at 6:36am
You are correct, the G mower is a #4. It shares may parts with the B/C and the #5. I have many NOS and used parts for those mowers. Find out what you need and go from there.
Lon(MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2020 at 7:05am
I am looking for the wood part of the swath board. I have all the metal pieces.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MStevens Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2020 at 12:34pm
So far I have the 90 deg gear box off. I need the two bearings that come from that. From what it looks like, it seems I’m gonna have to remove the brass pin that holds the bevel gear on to be the bearings out. Also, behind where the pulley mounts there is/was something installed in front of the first bearing. Had springs in it, it almost looks something like a clutch but doesn’t make sense for one to be there. Just a pile of rust now. Surprisingly the bevel gears are almost immaculate.
I have been able to get the main drive shaft to spin but haven’t dug into it yet.
Raymondjohn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Raymondjohn Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2020 at 8:01pm
I have a paper template I can send you to trace on a board of your own if you are interested, call me, 618-315-0821
Raymond
Post Options Post Options   Thanks (0) Thanks(0)   Quote MStevens Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2020 at 9:26pm
I need the 2 bearings and oil seal that’s in the 90 deg gear box. I got one bearing out so far the one next to the oil seal. I can make out an “E” and an “3” on it but that’s it. Do you know any info on these bearings?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Raymondjohn Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2020 at 12:08pm
The AC part number for the
oil seal is: 208417, that is by the hub shiv. And the bearing ball part number
is AC 210024. When you go to 90 degree by your gear bevel drive, that number
for bearing ball is AC 802379. If you have any questions, I have a parts book if you are interested. Let me know and I will send you the contact information to obtain one.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2020 at 9:42pm
Timber.Craftsman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Timber.Craftsman Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2025 at 3:44am
Bought a G sickle... Missing cutterbar need dimensions and possible source for a new / used cutterbar and pinion connector
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2025 at 8:30am
I have a G sickle mower I'd sell looks complete,been sitting a long time.Plus I have about a dozen or so B/C and CA mowers here.
This page was generated in 0.045 seconds.
