Model G alternator
pungobob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pungobob Quote  Post ReplyReply Direct Link To This Post Topic: Model G alternator
    Posted: 25 May 2023 at 7:10pm
Good evening all. I am in search of a mini Denso alternator for my G. My tractor had a12v conversion done when I it. The diodes have gone bad and when the battery is connected the alternator gets very hot and will drain the battery in less than an hour. If anyone has one please contact me. Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2023 at 6:30am
 Brillmam.com for anything and everything electrical.
Post Options Post Options   Thanks (0) Thanks(0)   Quote pungobob Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2023 at 4:11pm
Thanks for the info Paul. I will definitely check him out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2023 at 4:28pm
do you have a 1 wire alternator ?  Just a BIG LUG with a battery wire to it ?.. No small double spade connector ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote pungobob Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2023 at 4:56pm
Nope. Mine is an older Denso with the larger charging wire and a round plus with two wires.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2023 at 6:52pm
AMAZON........... or others ............ 30 amps is PLENTY big.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2023 at 6:58pm
