Model E engine serial numbers
49WF View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 49WF Quote  Post ReplyReply Direct Link To This Post Topic: Model E engine serial numbers
    Posted: 01 May 2019 at 9:17pm
I picked up three model E engines.
Would anyone know the years of the engines.
I know one should be a 25-40.
Engine numbers are 45641, 33408, 41437.
Any info or literature would be great.
More than I need
49WF View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 49WF Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2019 at 2:35pm
Bump
More than I need
Jacob (WI,ND) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jacob (WI,ND) Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2019 at 7:32pm
I can help a little.
My 20-35 early 1927 #8861 has an engine number of 33554
There is another 20-35 early 1927 #8375 in Makoti, ND with the engine serial number of 33050
So your engine number of 33408 is definitely a 1927.  An earlier one at that.  It should be a brass tag correct?
I'm guessing your 41437 would be a 1928.
My later 20-35 1929 #22807   with an engine serial number of 43753
So I assume your engine 45641 would be a 25-40.  Should be a lot of differences on this block vs the 20-35 blocks.
What are the CASTING numbers on your blocks?  That can help date them as well. The last two numbers change with the changes in the block castings.  Not an exact science, but can put you in the ballpark.  One of these days I want to compile a bunch of block casting numbers vs engine serial numbers vs tractor serial numbers and years to make a better chart to help ID things like this.
Jacob Swanson
1920 6-12; 1925,1926 20-35 longfenders; 1925,1926 15-25's; 1927,1929 20-35 shortfenders; C; B's; IB; WC's; WD; WD45
Gary(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2019 at 6:01am
What are the casting numbers
49WF View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 49WF Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2019 at 7:24am
One engine has a brass tag, I suspected it was older. I will get casting numbers. Thanks for the help
More than I need
49WF View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 49WF Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2019 at 7:40pm
The 25-40 engine has a casting # am 1153 26&27
More than I need
49WF View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 49WF Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2019 at 7:57pm
Bump
More than I need
49WF View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 49WF Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2019 at 10:26am
Bump
More than I need
