model d grader
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2024 at 6:25pm
In the Pacific northwest you are going to pay ~$2000 for a complete, running WD or WD45, then a road trip to haul it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2024 at 9:34pm
Kind of a long shot ... but LON (MN) has a LOT OF engines / parts / STUFF... Be a good drive to get there, but he "MIGHT" be able to makeup all the parts or a running engine that you need... Just a pickup truck load, no tractor.... Would at least be worth an e-mail to talk ... you got nothing to loose ???????
https://lonsallischalmers.com/for-sale/
Edited by steve(ill) - 30 Apr 2024 at 9:40pm
newbe2 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote newbe2 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2024 at 10:02pm
Thanks guys for the info, I will check it out
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2024 at 11:07am
got one here-- WD-45, wide front,-- aftermarket, 3-pt, factory ps. motor turns over .
Also have one partly taken apart an has 1 piston stuck in the sleeve yet. complete tractor.
Was going to put one in my D but found some M & W pistons/sleeve set to put in the old block keeping it original so everything fits back up like it s'posed to.
Post Options Post Options   Thanks (0) Thanks(0)   Quote newbe2 Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2024 at 11:46am
Thanks ac fleet appreciate the offer but Ill. is too far for me to go. I found 2 on marketplace in SE Utah. He claims they are WD and WD45 but advertised them as being made in the 40s. Rules out the WD45, unless he made a mistake on the year. It is planting season there so I am waiting until he has time to verify the year of the WD45. I am still looking locally, but not much luck.
This page was generated in 0.146 seconds.
