Model D Grader
kurto View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kurto Quote  Post ReplyReply Direct Link To This Post Topic: Model D Grader
    Posted: 20 May 2015 at 8:39pm
Hi everyone,
i am helping a pal try and find a starter for his model D grader that he just got.  the tag on the grader says model MD serial 3326.  it is a diesel but only 4 cylinder, i thought the D's had 6 cyl diesels.  is this motor something someone retrofitted or did some come with 4 cyl.  any help is appreciated, if a cyl diesel is standard does anybody kno what it is?  I am assuming it is a Buda.
thanks
DonBC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonBC Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2015 at 10:49am
That would make it a 1966 model year. It would have the same 4-cylinder diesel engine that was used in the D17D farm tractor or 175D farm tractor. Some of the vendors on this site should be able to help you.
Tony.Or View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tony.Or Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2015 at 12:04pm
Don !!  Diesels  were  6  cyl.    Gassers  were  4 bangers.   Sounds  like  some one  got  creative.     Tony
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonBC Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2015 at 12:40pm
Yes, you are correct Tony. I had a brain fart. Comes with old age. I have heard of other diesel engines being swapped into gas D graders so I guess a different model diesel engine in a DD grader would not be that unusual. Maybe that unusual MD in front of the serial number is trying to say something. Maybe it is a 1953 gas D grader that someone swapped in a diesel. If it is a round tube frame then it is an old 1953 D grader but if it is the newer square frame then it it would be a 1966 DD grader. The engine should have some kind of labelling such as Ford, JD, Perkins or a Japanese made engine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote kurto Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2015 at 5:07pm
thanks for the replies and thoughts. it is a round frame and looks 50's I would think. the serial number tag has been altered, as in someone cross checked the number and restamped (like maybe a dealership) I am new to this site and will try to figure out how to upload a pic or two to see if you fellas can figure out what this motor is.
Post Options Post Options   Thanks (0) Thanks(0)   Quote kurto Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2015 at 5:50pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote kurto Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2015 at 5:51pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote kurto Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2015 at 5:54pm
here is a pic of the injector and pump side. The pump is a Rossa Master again anyone that can help identify this thing is much appreciated . I did notice now that the tag has the name Shaw Sales, I am thinking the previous owner took this thing to Shaw and had a re-power....
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2015 at 6:27pm
Certainly looks like a WD45 Diesel engine, most definite an Allis engine. Would that interchange with a D series grader Gas??
Went back and looked at photo 1, has a WD series grill too.
Edited by DMiller - 21 May 2015 at 6:29pm
Dgrader View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dgrader Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2015 at 9:18pm
I think to put the 45 diesel in a gas grader you had to extend the frame 6 to 8 inches.
Ya cain't fix stupid.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonBC Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2015 at 9:43pm
He said that it was a 4 cylinder diesel so possibly not an Allis. It is a 4 cylinder engine in the picture. The sheet metal looks as if it might have been taken from an Allis tractor. It doesn't look like the typical D grader sheet metal. I am surprised that there aren't any tags or other information on the engine that would show the make. Those graders had a large adaptor plate on the bell housing so I don't think that it would be that hard to make up an adaptor plate for another engine. The same transaxle was also used in the small Galion graders as well and they may have had a 4 cylinder diesel that they used in their graders and someone found an engine from a Galion to put in their D grader..
Ian Beale View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ian Beale Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2015 at 10:01pm
DonBc
I've seen Galion 503's here with both IH 282 6-cyl and one with a British type IH 4-cyl as issued
ACjack View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACjack Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2015 at 9:18am
The engine looks like a Allis Chalmers D175 4cylinder diesel.
Ages Cat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ages Cat Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2015 at 11:18am
It appears to be a D-175. Same engine as our HD-3 crawler.
Curt Anderson
HD3, HD5B, HD6AG,HD6B dozer, I-400,615, 616,620,720,ACP25 lift truck, 1956 D Grader, AC 540 loader, AC #84 plow, Simplicity tractors, Agco MT225, Agco 2025,
Post Options Post Options   Thanks (0) Thanks(0)   Quote kurto Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2015 at 7:01pm
Well thats a couple of folks who concur on a D175 i will find a starter for one and give it a try... thanks for all the help. If anyone has a tell tell sign to identify as a d175 let me know what that is and i will look for that.
Ross D. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ross D. Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2015 at 2:15pm
DD grader at the 'Flywheelers' in FL. ( I am sorry for the size of the pictures).   Ross. .
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ross D. Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2015 at 2:43pm
Hi. Here are pictures of a D grader that had a diesel engine installed in it. The motor was transplanted from a Japanese diesel truck. It was used on a jughead training horse track near Toronto.    Ross.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonBC Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2015 at 4:46pm
it looks as if his grader has a 4 cylinder version of the 6 cylinder diesel engine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ross D. Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2015 at 6:48pm
Hi Don. Did the serial number on the Florida grader help with the motor I.D.?    Ross.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2015 at 10:53pm
I don't know what it is but it's a 4cyl Buda w/Lanova fuel system
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2015 at 5:12am
Ross, do you know what the hyd remote and brackets on the back of that grader are for?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ross D. Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2015 at 9:42am
Hi David.    I do not know what these brackets were used for. The owner did not know either. I wonder if this grader had the rearend A.C. bucket/loader on it originally. I do not have a parts breakdown for this loader. I believe that Gilbert Vust may have a grader with this backend loader in his museum.
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2015 at 9:51am
my nieghbors md has has a tool bar and rippers back there
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ross D. Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2015 at 11:49am
Hi Mike.   The scarifier toolbar on the 'D' grader was mounted directly in front of the operators platform. This California grader appears to have this toolbar on it. Some people will adapt a tool bar behind the grader framework. I believe that Don in BC. has mounted his unit there. You can see this toolbar in the picture of Calvin S. on this 1967 'D Special'. I noticed that the air breather is different on the one from California, than the one from Florida.   Ross.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ross D. Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2015 at 11:53am
    Sorry, the picture did not load properly.     Ross.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2015 at 6:37pm
Don't think its the loader bracket, that mounted further forward on the grader, according to the picture in Norm's book...
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2015 at 7:40am
Ross, that grader operator looks highly skilled by the look of the job he is doing!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonBC Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2015 at 11:32am
Yeah Ross that operator is doing a great job. Going back to that 4 cylinder diesel in that grader, from the pictures it appears as if it a 4 cylinder version of the 6 cylinder engine. I know next to nothing about Allis diesel engines so I have no idea what model tractor that might have used it but it must have been a relatively easy swap.
Yes I did mount a ripper on the back of my D grader. It came from a JD 450 crawler loader so it is pretty rugged. The so called soil here often has boulders and decomposed sand stone so the ripper comes in handy. I also fabbed up a blade to fit on the ripper brackets primarily to be used in the winter to work snow in and out of corners. It has never snowed enough since I made it to even bother putting it on.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2015 at 5:48pm
Works perfect, then...
This page was generated in 0.414 seconds.
