Model C PLowing help wanted
Gafry53 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gafry53 Quote  Post ReplyReply Direct Link To This Post Topic: Model C PLowing help wanted
    Posted: 28 Mar 2021 at 10:51am
I have an Allis Chalmers model C with a single plow.  I would like to know how to set the plow depth? There are 2 levers on either side of the tractor seat. The one on the right will raise and lower the bar the the plow is attached to. When plowing  the tractor pulls to the right and the plow does not seem secure at the lift mechanism as it also moves around. When running a second path the tractor pulls to the side the tire has more traction. You can call or text me at 717-449-8281 thank you for any help.
