Model C paper Shims
kelso View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kelso Quote  Post ReplyReply Direct Link To This Post Topic: Model C paper Shims
    Posted: 16 Jul 2020 at 6:33pm
I am working on rebuilding a 1949 AC model C. I have removed parts that have metal shims and paper shims.  Some of the paper shims are reusable but some are broken.  I think the thickness of the paper shims is .005.  Is there a source for these paper shims or material I can cut them out of?
I am currently working on the Finial Drives and the retainer shims part number 208223.
Thanks for any help,
Tim
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2020 at 6:51pm
I cut some out years ago... just used brown wrapping paper... have also used white note book paper........... paper is so you dont have metal to metal which may leak.
Edited by steve(ill) - 16 Jul 2020 at 6:54pm
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2020 at 9:45pm
We used to use manilla folders.
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2020 at 6:03am
Paper is paper for that application. Make sure you measure the gear back lash or bearing drag when replacing paper shims. Paper shims are in fact shims and the  thickness is important.
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2020 at 7:34am
Probably still available from AGCO if you have a good parts man.
Ted in NE-OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted in NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2020 at 2:32pm
The purpose of the paper shims is to keep oil from seeping between the metal shims, when I do not have reusable paper shims , I use gasket cement and adjust accordingly
Post Options Post Options   Thanks (0) Thanks(0)   Quote kelso Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2020 at 10:52pm
Thanks everybody for your information.  I will try several of these approaches.
Another question: Are the terms gasket paper and shim paper used interchangeably? I can find gasket paper which I can try also.
Cheers,
Tim
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2020 at 1:51pm
Psper grocery bags are perfect substitute for paper shims
Boss Man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Boss Man Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2020 at 3:19pm
In my mind it would be the same thing. There are several types and thickness of gasket paper. I took an engine apart that had gaskets made from Beer cases anywhere there was supposed to be a paper gasket
Edited by Boss Man - 18 Jul 2020 at 3:19pm
