Model "B"&CA fuel lines? |
Hunt4Allis
Topic: Model "B"&CA fuel lines?Posted: 05 Apr 2018 at 10:38am |
Both my B and CA fuel lines leak when I turn off fuel at bottom of bowl
Best fix? Any specific type copper lines or fittings? |
The Consultator
Joined: 19 Sep 2017 Location: Rio Rancho, NM Points: 120 |
Posted: 05 Apr 2018 at 10:41am |
I had to loosen and adjust the alignment of my B's line going into the bowl. It they are just a bit wonkey, the nut won't lock down enough to squeeze the flared end into the bowl. I also used plumber's tape on all the threads.
Edited by The Consultator - 05 Apr 2018 at 10:41am |
1939 Allis-Chalmers "B" restored in 2010- very good condition.
Hunt4Allis
Posted: 05 Apr 2018 at 10:42am |
Ok, maybe I just need to add tape( is it fuel specific type or just Teflon?)
The Consultator
Posted: 05 Apr 2018 at 10:51am |
I just used Teflon from Napa. Nothing special. It took a few tries to get everything lined up. Remember that the threads and fittings are soft metal, and if they are off a bit, it can be easy to strip them out when tightening them down. I had to adjust my fuel bowl positioning as well. Luckily I had room to play and still remain sealed under the tank.
Hubert (Ga)engine7
Joined: 12 Sep 2009 Location: Jackson Cnty,GA Points: 6504 |
Thanks(1)
Posted: 05 Apr 2018 at 11:01am |
Be careful if you use teflon tape and don't let a small piece get into the carb. Steve in NJ (bb-customcircuits.com) makes excellent replacement fuel lines if you need some.
The Consultator
Posted: 05 Apr 2018 at 11:03am |
Indeed. Steve does exceptional carb work as well!
Hunt4Allis
Posted: 05 Apr 2018 at 11:11am |
Where mine is leaking from is right at the little wing nut valve
Jim Hancock
Joined: 11 Sep 2009 Location: EL Reno, Ok. Points: 1112 |
Posted: 05 Apr 2018 at 11:59am |
Have you tried tightening up the packing nut some?
How blessed we are by HIS GRACE!
Hunt4Allis
Posted: 05 Apr 2018 at 12:00pm |
No, but will
Joined: 11 Sep 2009 Location: illinois Points: 88595 |
Posted: 05 Apr 2018 at 12:06pm |
If that doesn't seal it up, unscrew the nut all the way and pull the nut and needle valve off the tractor. Look a the packing... sometimes you can take a small piece of string a couple inches long and wrap it around 5-6 times and give the old packing some BACKUP and then you will have enough adjustment to seal the leak.
Hunt4Allis
Posted: 05 Apr 2018 at 12:09pm |
Thanks guys
Dick L
Joined: 12 Sep 2009 Location: Edon Ohio Points: 5093 |
Posted: 05 Apr 2018 at 12:18pm |
Copper is not a good choice for your fuel lines. Copper is soft and you can over tighten copper to where when you retighten after removing the line it will not seal properly. Steel brake line is the best. The very best would be to flair the ends but the compression fittings are good on steel also. Teflon tape is good on the fittings pipe threads as well as any good pipe dope. Keep the tape back from the first thread and it will not give a problem. Tape or dope on the compression nuts does no good. |
Hunt4Allis
Posted: 05 Apr 2018 at 1:06pm |
Both my model B and model CA have copper gas lines
sparky
Joined: 13 May 2011 Location: So. Indiana Points: 1791 |
Posted: 05 Apr 2018 at 1:11pm |
I suggest steel replacement like factory.
Dakota Dave
Posted: 05 Apr 2018 at 1:51pm |
If it's leaking fuel with the valve turned off the problem is not the fuel lines. It's the packing on the shutoff valve. When you turn the valve on and back off the compression nut behind the wing nut there is a packing in there. Try to tighten that first. If that fails your best bet is replace it. Unfortunately you need to buy a new sediment bowl assembly. As that packing is not available.
Dick L
Posted: 05 Apr 2018 at 6:48pm |
You can make your own packing for those with the Teflon tape. spin the tape in your fingers to make it like a string and wrap it around the stem in front of the cap. A waxed string works also. |
Hunt4Allis
Posted: 05 Apr 2018 at 6:49pm |
Good to know
Thanks all |
cjallis
Posted: 05 Apr 2018 at 6:50pm |
If it still leaks. I suggest getting new fittings and maybe fuel lines off Ebay or Steiner says the original lines.
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5163 |
Posted: 06 Apr 2018 at 3:57am |
There was an extensive discussion on fuel line a week or so ago. Copper is maybe about the worst choice for a line for hazardous material. Much too easilyprone to cracking and leaking from vibration.
Hunt4Allis
Posted: 06 Apr 2018 at 4:04am |
Ok, good to know
Ted J
Joined: 05 Jul 2010 Location: La Crosse, WI Points: 18943 |
Posted: 06 Apr 2018 at 1:43pm |
Brian Jasper co. Ia
Posted: 06 Apr 2018 at 8:18pm |
There's nothing wrong with using copper for a fuel line. I have a large collection of old small engines and most of them that use a separate carb and tank like Lauson did use a copper fuel line. The bowl with the wing nut is your fuel filter. It's not a good idea to use any sort of sealer because little bits can end up breaking loose and going to the carb and block the float valve, jamb the float valve open, or end up in a jet. Because of the length involved I would recommend using steel. You can buy steel lines with double flare fittings like used for brake lines. There is also NiCop (nickel copper) that is also approved for brake use and is much easier to bend. Those sediment bowls if they leak, can be frustrating at times to stop from leaking. New ones are not that expensive.
