model b trans broken |
Post Reply |
boom
Bronze Level Joined: 29 Jan 2010 Points: 6 |
Posted: 23 Feb 2010 at 5:16pm |
I am tryin to restore a early 40s model b and when i crank it over in neutral it starts to move forward when i push in the clutch it stops movin. Im thinking one of the gears is rusted to the shaft? but im not sure, any ideas thanks
CTuckerNWIL
Orange Level Joined: 11 Sep 2009 Location: NW Illinois Points: 22823 |
First if you don't have one already buy a manual. It will more than pay for itself when wrenching on your B.
It is possible the shifter is no longer engaged with a gear and when the lever appears to be in neutral, the transmission is still in gear. You may want to drain the transmission fluid(probably got water and crud in it anyway) and take the side cover off to inspect the tranny. Once you find the problem you can repair it and clean things up.. |
boom
ive takin it out every thing looked clean as could be and when i pulled it out the shifter seemed like it was where it was supost to be
Orange Level Access Joined: 11 Sep 2009 Location: illinois Points: 82315 |
push the gears into the neutral position with a screw driver. Leave the side cover / forsk off. See that everything turns by hand. Crank the motor and see if it still moves. Top shaft should rotate toward the PTO, but lower shafts and gears are not engaged.
Walker
Orange Level Access Joined: 12 Sep 2009 Location: oh Points: 8573 |
If it is kind of a half hearted lunge I would suspect the clutch is hanging up on the splines. Now if it is doing a leap frog type of thing it must be stuck in two gears.
Dick L
Orange Level Joined: 12 Sep 2009 Location: Edon Ohio Points: 5087 |
Sounds like one of the forks on the side plate is not engaged in the one of the gear grooves. It is real easy for one of the slide gears to move when re installing the side plate.
Post Reply | |
