Model B Starter Coils |
cfciii03 ![]() Bronze Level ![]() Joined: 20 May 2021 Location: 43560 Points: 29 |
![]() ![]() ![]() ![]() ![]() Posted: 26 Feb 2022 at 10:10am |
Have a 1955 Model B. Starter not working. Found the starter coil leads have separated from the copper terminal. Is it possible to reconnect ? If so, how ?
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 87593 |
did they break or did the starter get HOT and melt the solder ?
AaronSEIA ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Mt Pleasant, IA Points: 2570 |
What are you calling the starter coil? Original starter used a push rod and button switch similar to the WD. No coil anywhere. AaronSEIA
Les Kerf ![]() Orange Level ![]() Joined: 08 May 2020 Location: Idaho Points: 1254 |
They can be re-soldered but you had best be really good at soldering
![]() ![]() As mentioned above, I would first want to know what caused them to become loose. |
WF owner ![]() Orange Level ![]() Joined: 12 May 2013 Location: Bombay NY Points: 5010 |
I assume he is talking about the field coils inside the starter.
Yes - we are talking about the coils within the starter. The copper leads from the coils are supposed to be soldered to the copper terminal. For some reason (maybe a poor prior repair) the solder cracked and the leads are no longer attached. Can the leads simply be resoldered ? If so, what solder to use ?
DaveKamp ![]() Orange Level Access ![]() ![]() Joined: 12 Apr 2010 Location: LeClaire, Ia Points: 6066 |
If the solder cracked, it's either because it wasn't properly soldered, or the terminal and lead relationship was stressed enough to fracture the soldering. They CAN be soldered... a rosin-core solder, and a POWERFUL soldering rig. A BIG soldering gun might do it... but a torch-type heated tip iron would be best. The reason why it'll be so difficult, is because the copper terminal will pull the heat away FAST. Thermal transfer coefficient of copper is very high, that's why it's a preferred heat-sink material. This being the case, it will tend to pull heat away from the solder point. A propane torch would work, too, but you'll be faced with melting the smaller wire away, too. Get in there with lots of heat, get the terminal hot, get solder on it, heat the wire quick, put 'em together, flow it, and get out. What you do NOT want to do, is get the copper so hot that your flame changes to green... when that happens, you're destroying the copper.
1939Dodge ![]() Orange Level ![]() Joined: 18 Jan 2014 Location: Pa. Points: 554 |
First thing I would do is talk to Steve at B&B Cusrom Circuits
This is really good advice. I recently rebuilt the dead 6 volt starter for my Model C by purchasing a 12 volt kit from Ebay, complete with armature, field coils, terminal, bushings, etc.. I had to solder those field core leads to the terminal using a torch; I have a pretty good grasp on soldering (avionics tech, biomed tech, general electronics tech, etc. since the mid 70's) and I achieved a good bond, but there isn't much room for error. I have no clue as to the quality of the the kit but I seriously doubt it is as good as what Steve provides. |
Steve in NJ ![]() Orange Level Access ![]() ![]() Joined: 12 Sep 2009 Location: Andover, NJ Points: 11992 |
Coming into this a bit late, but to be honest, I don't get involved with repairing field coils. Once a weak link, always a weak link on them. Don't ask how I know that. LOL! Yeah, I tried to repair them numerous times in my early years of rebuilding, only with failure at the end. I always just install a new pair of fields and be done with it. Dave's last sentence pretty much say it all....... Steve@B&B
jaybmiller ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24649 |
You might try a 'silver' solder or a 'hard' solder. CLEAN the wire and lug first, bright and shiny, 'tin' both, then solder them together. I do have a 250W iron here, 1" chisel tip..takes 'forever' to heat up BUT it's great at repairing 'big heatsinky' things....
