Model B parts
Message Reverse Sort Order
1939Dodge View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1939Dodge Quote  Post ReplyReply Direct Link To This Post Topic: Model B parts
    Posted: 20 Jan 2017 at 9:33pm
I found the hydraulic line!! It also looks like the clutch pad was an aftermarket item, it's on a sleeve that slips on the pedal. Held in place with a cotter pin.
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2017 at 3:10pm
You can get the steel tube at NAPA. Brake line.
I never saw a rubber pad on a clutch pedal. Bob
4 B's, 1 C's,3 CA's, 2 G's WD, D14, D15, B-1, B10, B12, 712S,
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2017 at 4:17pm
Don't forget e-bay.  I surf there from time to time and it is surprising what you can find on that site.
Take good care of my favorite
Good Luck!
Bill Long
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1939Dodge Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2017 at 12:25pm
Thanks, I need to either find the steel outlet tube by taking apart my entire garage and finding it, or buying another. Whichever method is less painful wins.
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2017 at 11:04am
Have several two way valves. Might need seals, not sure.
Can't fix stupid
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1939Dodge Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2017 at 10:44am
Anyone know where I can get a new clutch pedal rubber pad, and an outlet tube between the hydraulic pump and the two-way hydraulic valve?
This page was generated in 0.215 seconds.
