Model A carburator
Wot View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wot Quote  Post ReplyReply Direct Link To This Post Topic: Model A carburator
    Posted: 25 Mar 2019 at 4:08pm
Hi guys,
My A won’t run good. When I look in the manual I think the carburator isn’t the original one.
The parts manual says it needs to be E-2189 (Zenith)
Who knows what the correct Zenith number is? (Maybe it is the same as a model 20-35?)
Thanks in advance!
AC: B / WD / CA / WC unstyled / U / 7060 / 710
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2019 at 10:17pm
Hi Wot!
Funny you should ask that... I was just reading the November/December 2017 issue of The Restorer:  The Model A Ford Club of America... article starting Page 8:  A Guide to Zenith Carbeurators - Part 5, The 1931 Zenith Carbeurators and Beyond, by Steve Schumach, Spokane, Washington (USA).
I was amazed by the variations that occurred just in 1931.  I suspect that you'll find that your year has it's own variations as well.  Many of those Zenith carbeurators were NOT made by Zenith, many were made under liscense by Ford, through their suppliers.
the Model A Zenith had one feature (the mixture control/choke rod) that was kinda unique to the Model A Ford.  i don't know if the 20-35 used that type of control, but I would NOT be surprised if it was similar, and I would NOT be surprised if someone fitted a Model A carb to something else.
You say yours 'won't run good'... that sounds normal.  My dad's '29 A pickup won't 'run good'... but it won't 'start good', and certainly won't 'stop good'... it has the factory-standard 'anti-lock brake' feature... step on the brake, and three of the four won't work, but one will lock.  Release, and step on it again, and one of the OTHERs locks, and the rest don't Shocked  The ride is rough, the steering is spooky, exhaust is smelly, the clutch chatters, the battery is always weak, and it tends to get overheated in parades.
Kinda... well... alot... like my wife... Ouch
LOLLOLLOL
send me an Email address, and I'll take some good pictures of the pages of this article for you.
Edited by DaveKamp - 25 Mar 2019 at 10:18pm
Leesok View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leesok Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2019 at 12:24am
C6EV   Zenith
Wot View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wot Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2019 at 1:23am
Ok, thanks!!
Another question, how is the timing correct for these engines? I have a SPARK and a CENTER line on the flywheel. When does it neet the spark, and are those lines spark and center for cylinder one?
Is cylinder one the one at the radiator side?
Thanks.
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2019 at 3:51am
The old mag tractors had a mark for 'fire'. When turning the engine over, the magneto was to trip at that moment, which was the after TDC so the cranker didn't get cranked himself. And when the tractor started, the advance in the magneto was set to be of proper advancement for that engine.
 I am remembering the 35/K crawler said the mag had a 25 degree lag on the impulse and the engine was to be set so the mag would trip at 5 degree past TDC and when the impulse quit retarding the spark, it was advanced to 20 degrees BTDC for spark to occur. Hope that helps.
everett048 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote everett048 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2019 at 4:53am
early carbZenith c6ev
later carb Zenith 62AJ12
Butch(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2019 at 5:17am
As Mr Everett said it depends on what year it is and it also depends on which fuel was used. The all fuel tractors all used the C6EV to my knowledge.
Timing marks and timing your tractor. When visable in the timing window CENTER designates that pistons 1 and 4 are at top dead center. SPARK, FIRE and IGNITION were all used at various times amd all mean the same thing. That is where spark should occur when the engine is running. If you hand crank that tractor and value your limbs pay close attention here. The impulse on the magneto must NOT trip prior to when CENTER appears in the window. IF your magneto has the correct impulse coupling in it and you set it so it trips at CENTER when hand cranked then your timing will be at SPARK when running. It is of course up to you to figure out if #1 or #4 is at TDC of the compression stroke. Yes #1 is closest to the radiator.
Edited by Butch(OH) - 26 Mar 2019 at 5:19am
Post Options Post Options   Thanks (0) Thanks(0)   Quote everett048 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2019 at 7:02am
K crawler was fitted with same carbs early 1 had the C6EV later 62 AJ 12
both dual fuel carbs 1 has cork float 1 has brass float.
Wot View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wot Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2019 at 3:21pm
Ok, thanks for your help guys!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2019 at 11:25pm
Duhp... Confused I thought he was referring to a Model A Ford...
(must've been a Monday)
Sorry!  LOL
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2019 at 7:30am
U say it will not run good ,It is VERY INPORTANT to have correct hot mag also. Fire out side cylinder is not the same under compression.
 Just what is it doing  ? .
Edited by Fred in Pa - 27 Mar 2019 at 7:33am
nonetheless ,still dead.
Wot View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wot Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2019 at 4:14am
Got it running yesterday, don’t exactly know what the problem was. Checked timing again, float level in carburator, valve clearance...
runs verry smooth after 35 years standing without running!
Thanks again!
Wor
This page was generated in 0.071 seconds.
