Model 83 - 3 POINT PLOW |
Tracy Martin TN ![]() Orange Level Access ![]() Joined: 11 Sep 2009 Location: Gallatin,TN Points: 10756 |
![]() ![]() ![]() ![]() ![]() Posted: 27 Apr 2012 at 10:27pm |
This plow seems taller than my other plows. My manual doesn't mention a high clearance but is definitely taller than my others. Is the stub beam longer on the high clearance? Did Allis make differant height plows in the 80 series? "http://i195.photobucket.com/albums/z306/5683tracym/Picture017.jpg" border="0" alt="Photobucket"></a>
"http://i195.photobucket.com/albums/z306/5683tracym/Picture016.jpg" border="0" alt="Photobucket"></a>
"http://i195.photobucket.com/albums/z306/5683tracym/Picture015.jpg" border="0" "http://i195.photobucket.com/albums/z306/5683tracym/Picture014.jpg" border="0" alt="Photobucket"></a> Edited by Tracy Martin TN - 27 Apr 2012 at 10:46pm |
JeffMOnt ![]() Silver Level ![]() Joined: 11 Sep 2009 Location: Ottawa, Ont Points: 129 |
Jeff, please tell me how to post that photo the way you did that. Hannah is ready to kill me! Thanks Tracy Martin
Easiest way is use the full reply editor, not the quick post. In the post box click on the button beside the A the one with the arrow pointing to the upper right. In their click on the insert image button (looks like a tree). Input the image url, in your case it would be http://i195.photobucket.com/albums/z306/5683tracym/Picture017.jpg and for the width enter 640 and height enter 480. This gives it a decent sized image. Hope that helps.
Jeff |
Gerald J. ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Hamilton Co, IA Points: 5636 |
I've not seen any mention of tall vs short shanks in the plow frames book I have. Its available on line from http://www.grandpastractor.com/phpBB3/index.php You might look to see if its shown under 9000 in that book. I didn't think 83 would have the top beam, but I could be wrong. I don't have that parts book at the computer tonight. There is a spring trip shank shown separately that the description says for model 60 and 80 plows, separate from the spring trip shanks shown in the model 80 plow frames. Look at the spring trip arrangement as it could have changed with time.
Gerald J. |
JoeO(CMO) ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Cent Missouri Points: 2696 |
Tracy, yes they did make a taller high clearance plow.
I have a model 82, 3-point plow, nothing modified and 3 inches taller.
Dave (Mid-MI) ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Hemlock, MI Points: 566 |
The truss bar on top of the plow frame was standard on a 4-bottom plow and was optional on the 3-bottoms. My brother has a similar plow that would barely clear the ground on his D-17IV. He switched out the stub beams with some from a 9000 plow which were about 3" shorter.
CTuckerNWIL ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: NW Illinois Points: 22825 |
Tracy, If you copy the Image code from photobucket, all you have to do is paste that code in with your text. It's real simple. with the url you posted you need a set of brackets [ ] with img inside em and at the end you add a / between the first bracket and the img.
If you add the brackets to a picture URL you can post any picture you find on the web in with your text, even from the quick reply space. |
I can't tell relative shank length from the parts book. But the trip is typical of later rather than earlier spring trip shanks, like applied to the 9000.
Longer shanks take a stronger trip mechanism but slow down plow plugging in corn stalks. I've come to like a semi mounted plow on a long frame like my 2000 over a closely coupled three point because the greater front to rear spacing is harder to clog. Some IH 720 and 740 have much longer shanks to raise the beam further and have a great reputation for handling corn stalks very well. Gerald J. |
I took a look at the plow today versus my others. Trips on it just like my 82 -3 point. I have a 4 bottom SC with differant trips on it. The sring at rear of beam has a triangle shaped holder it rides in. The plow in pic, matches pic of plow in my manual as an 83, and has the truss beam on it. Wondering what the other plow would be? Didn't take any pics. Thanks Tracy
WD45 ![]() Orange Level ![]() ![]() Joined: 20 Sep 2009 Location: STAYNER,ONTARIO Points: 956 |
Nice plow Tracy - we have an 83 series S/C plow with the extra bar on top plus a gauge wheel.
Fred Dunlop, G,B,CA, WC,WF, 3 WD45`s,gas, diesel and LP,U,D10 series III, D12,D14,D15 SERIES II,D17 Series IV in Gas and Diesel ,D19 GAS and D21,170 185,210 ,220 an I-600 8070 fwd, 716H and 1920H
Thanks Fred, I have a 73 SC with gauge wheel, it came with a D15 I bought. I have an 82 - 3 point that needs alittle TLC. Stop by on your travels when you can. Always nice to visit. Hannah says HI.Tracy Martin
